Problem with non-dimming 11.6 screen
Discussion in 'Prime Main Forum (2017-2022)' started by LouG123, Dec 4, 2017.
  1. LouG123
    LouG123 Member
    49
    47
    Vernon Hills, IL
    So very early this morning is the first time I have experienced an issue with my 11.6 screen not dimming when dark outside. Not only is it not dimming, but the car's headlights do not appear in image on the screen when turned on. I did check this morning and my screen is NOT set to the "Day" mode.
    I have also had a couple instances when my screen randomly reboots when I'm driving, but if this is anything like the NAV screen in my 2014 Toyota Highlander, it may mean that the software needs to be updated.
    Just curious to know if anyone has experienced problems with the 11.6 screen not cooperating at night when headlights are on and not set to "Day" mode.....
    HPrimeAdvanced likes this.
  2. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,303
    3,519
    Anaheim, CA
    Check the dimmer controls on the left side of steering wheel (not ON the steering wheel, just to the left); it might be locked to the "Non-dimming mode".
    Mark57 likes this.
  3. Pizza Driver
    Pizza Driver Active Member
    158
    156
    United States
    Occasionally I have had the screen not dim automatically. When that happens I knock the dim switch down one notch and it dims like normal. So, apparently, that setting may just reset itself occasionally.
  4. Mendel Leisk
    38,736
    Just assuming it's sim to 3rd gen, there's a knurled wheel, as you roll it up the screens get brighter, till you encounter resistance to further turning. Leave it there, it's at full bright, but will auto-darken still.
    But push that wheel a little further, it goes through that resistance, to the top, which is the same full bright, but stops the auto-darken function.
    Maybe that's what you've done?
  5. HPrimeAdvanced
    2,303
    3,519
    Anaheim, CA
    Mr. Leisk, that's what I too think happened; the controller is different without that "flexible stop". It's just a 2-headed switch, one side "+", and other side with "-", no detent that I noticed.
    #5 HPrimeAdvanced, Dec 4, 2017
  6. LouG123
    LouG123 Member
    49
    47
    Vernon Hills, IL
    Many thanks to HPA for the answer.....!
    I must have pushed the button to long by accident, but this was the culprit....
    BTW - Prime Advanced was purchased on June 20, 2017 and as of today I'm now at 10,600 miles. I really like this car....!
    Mark57 likes this.
