Problems after Battery Modules Changed/Balanced
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by undertoad, Nov 29, 2017.
  1. undertoad
    undertoad Junior Member
    17
    Seattle
    Having continued problems on 07 Prius with 208k miles. Got the red triangle and codes for traction battery problems.
    I pulled the battery. It had two bad modules. I changed them and then used a grid charger/balancing device from Hybrid Automotive. All modules balanced at 8.2v, plus or minus 0.02v, after sitting all night.
    Installed the battery, and everything's fine for about a minute, and then the orange triangle and several other dash lights light.
    Hooked up my OBDII and used Torque to scan for fault codes. Result was no fault codes. Disconnect 12v battery to re-set, and the same happens again after about a minute. It runs and drives fine, and the fanis not blowing constantly, like it was.
    What can I try next? Is there any way using the Torque to see what the battery voltages are?
    Thanks!
    52,912
    mini vci.
  3. JC91006
    16,939
    8,647
    The triangle may not be related to the battery. But there's definitely codes if the triangle came up
  4. undertoad
    17
    Seattle
    Not sure what that is. Can you explain further?
  5. undertoad
    17
    Seattle
    I'll go check again for codes. There were none last time.
  6. bisco
    52,912
    code reader with toyota tech stream software. 25 bucks on amazon, and you need a compatible laptop.
  7. undertoad
    17
    Seattle
    Still no codes, but now the Ready light does not come on, it can't be shifted into D or R, and the Brake light stays on, in addition to all the other lights.
    Any ideas?
  8. undertoad
    17
    Seattle
    All I have are Macs, unfortunately.
  9. LEVE
    LEVE Member
    191
    97
    On the Willapa
    Perhaps you can run XP on the Mac in a Virtual Machine!
  10. undertoad
    17
    Seattle
    I'm not that smart, unfortunately.
  11. bisco
    52,912
    me neither.:unsure:
    Raytheeagle likes this.
  12. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    If you think it is the battery set up your torque to watch all voltage of all 14 battery blocks on one screen.
    that take some snapshots of live data under load.
  13. undertoad
    17
    Seattle
    Now, it won't go into Ready mode, and it still isn't throwing any codes, so I cannot load the battery, so far as I know. Any ideas?
  14. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    What is your 12v battery voltage reading?
  15. undertoad
    17
    Seattle
    Will check it tomorrow.
  16. strawbrad
    953
    1,007
    Try disconnecting and reconnecting the 12 volt battery. That will clear most codes, even the ones that your reader can't see. If it goes ready and then lights up again you most likely have a high voltage leak. That's the only thing that will cause a one start and done. When the leak code is set the car will drive fine until shut off but will not restart.
    Brad
  17. undertoad
    17
    Seattle
    Thanks. Will try that tomorrow.
