Problems after Hybrid battery reinstall
Discussion in 'Gen 2 Prius Technical Discussion' started by Jason Anderson, Sep 16, 2017.
  1. Jason Anderson
    Jason Anderson Junior Member
    Harrisonburg, VA
    Hi Prius members I have a 2005 Prius 170,000+ and I just had the hybrid battery cells rebalanced and got the battery back today. My dad took the battery out and I took it to them and dropped it off. I used Dr. Prius in NoVA. Nice and friendly business. But tonight after my dad put the battery back in and we put the key in and hit the start button, everything was lit up on the dash, parking brake light and all across the board. Not sure what is wrong? When I try to shift gears it just defaults to neutral and says to put it in park, caution. I did have an issue with the 12v battery dying while the car sat in the garage till I found the rebalanced business. My dad charged the 12v battery and put it back in tonight. I've read that it could be that? Or the orange lever thingy not being rotated right? The battery levels on the consumption screen had grey bars, whereas before there were none before we got the battery rebalanced. Any help would be greatly appreciated. I'm going to get my dad to get codes and see if that is it and I guess we need to read the voltage of the battery while it's on? I just hope this clears up, I've missed my prius so much. I do have a warranty with the rebalanced job I had done.
    51,155
    check the 12v cold voltage after off for a few hours. also, try pressing the power button a couple times.
  3. Prodigyplace
    12,407
    11,682
    Central Virginia
    I suspect @ericbecky and some of the other experts will be by shortly.
    Using the "@" sign like I did tags a user so they get an alert they were mentioned.
  4. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    bisco is correct, after reinstalling the HV pack you need to press the start button twice while keeping your foot on the brake pedal to start it.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Yep just like after u install a new 12 volt battery.
    But if that don't work turn on the headlights and see if they are bright. If so check the orange safety switch is installed correctly,
    Slide it down then flip the lever down.
  6. edthefox5
    10,096
    4,831
    Clearwater, Florida
  7. Jason Anderson
    Harrisonburg, VA
    Thank you all so so much. So it ended up that we just needed to unhook the 12v while it was off and then when I restarted it I got the System loading on the screen do not power off. I then hit the start button twice real quick and then it felt like it kicked in and all the lights went out. Funny thing was that of course you can't do any driving with the door open, so after that it all seems great. Knock on wood, thanks again!!!
    Prodigyplace and bisco like this.
  8. bisco
    51,155
    congrats!(y)
    Prodigyplace likes this.
