problems filling the gas tank
Discussion in 'Gen 2 Prius Technical Discussion' started by c_ocean, Sep 22, 2006.
  1. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    <div class='quotetop'>QUOTE(ScrewedByToyota2006 @ Nov 1 2006, 08:44 AM) [snapback]341849[/snapback]</div>
    This is the first I've heard but I'm seriously concerned about this issue because, like you, I have a 2004 package 9. Please let me know how many Prii to date have reported this issue so that I can calcualte my chances for developing this issue. Once I know the universal-ness of this problem I'll decide whether to take Priapus to the dealer before I encounter the problem. Also, what symptoms did you notice before the bladder issue arose or did you notice any? If you did, were they consistant with what others have encountered before needing their tanks replaced?
  2. sparky2006
    sparky2006 New Member
    I have attached some links to internet postings of people who are having fueling problems with their Prii. Just doing a Google search will yield many others for you to look at:
    http://www.hybridcars.com/forums/archive/i....php/t-353.html
    http://priuschat.com/index.php?showtopic=25799
    I believe that the problems with the inaccuracy of the fuel gauge, as well as trouble with fueling and needing to use a slow fueling rate from the nozzle are related to defects in the Prius bladder.
    My main point is that, if we as Prius owners bring our cars to the dealership and report these problems when the car is STILL UNDER WARRANTY, then when/if the bladder completely fails, and you need an entirely new fuel tank at 42,000 miles as I did, then it should be covered under warranty.
    I had no advance warning of the problem other than what everyone else describes with their Prii. Trouble fueling at certain gas stations because the nozzle immediately clicks off, and inaccuracy of the fuel gauge.
  3. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    <_< I do not rate the fueling peculiarities for the Prius to be a "problem," rather the nature of the fuel bladder system. For some of the 2004's and 2005's there was a TSB (Techincal Service Bulletin) which would modify the fueling system by replacing the filling tube into the tank, changing out the speedometer/fuel gauge module (which would require having the current odometer reading programmed into the new module to reflect the true odometer reading). This required dissambly of the dash and fuel tank area and many Prius owners subsequently reported no change in the fuel gauge accuracy. To preserve the odometer reading, the speedometer/odometer module had to be programmed by a Toyota technician, not your friendly local dealer, thus a several day wait while your Prius sat idle at the dealer was required. I elected to NOT have this done at the time.
    If you're really interested, try searching on "Fuel gauge" or "Fuel Gauge Inaccuracy" etc. Unless you have a 2004 or early 2005, I would not expect Toyota to modify the fuel system under warranty. This is definitely NOT some conspiracy by Toyota as some may have implied.
  4. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(Charles Suitt @ Nov 2 2006, 04:28 PM) [snapback]342911[/snapback]</div>
    Inaccurate information alert.
    An odometer reading was taken and a part ordered with the car's current mileage. The car did not have to stay at the dealership. The owner was free to keep driving it. When the new module arrived, the owner returned to the service department to have the new component installed.
  5. yups
    yups Junior Member
    67
    Tucson
    I've noted that if the car isn't level especially if the tank oriface is oriented downslope, there can be premature pump shutoff. the once or twice that the pump has shut off early, the tank opening was pointing toward the downhill side of the unlevel fueling bay.
  6. Dr Ed
    Dr Ed New Member
    188
    Pump switch-off sensors have varying sensitivities. One pump at my favorite station is unusable on my Prius because it clicks off constantly. All other pumps at that station work fine.
  7. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
  8. Jmad1138
    Jmad1138 New Member
    55
    I have a little more than 2K on the ODO the last two fills I could not fill the tank up to any kind of capacity and the gas gauge reflected that only showing about half filled. I will try some suggestions here but it seems like a problem to me. I like to be optimistic and consider the tank half full, not half empty.
  9. Frank Hudon
    Frank Hudon Senior Member
    4,147
    2004 Prius gas tank part number 77001-47080 Price $322.18
    labour to replace 1.8 hours so $400 dollars seems to me like ScrewedByToyota2006 got screwed by his favourite dealer as well.
  10. Mary Snyder
    Mary Snyder New Member
    132
    <div class='quotetop'>QUOTE(Frank Hudon @ Dec 7 2006, 01:06 AM) [snapback]358758[/snapback]</div>
    Do these problems apply to the 2007 Prius also?
    Mary
  11. nicoss
    nicoss New Member
    304
    <div class='quotetop'>QUOTE(ScrewedByToyota2006 @ Nov 1 2006, 06:44 AM) [snapback]341849[/snapback]</div>
    We have beaten this issue to death & beyond :angry:
    Kegel exercises :lol:
    Bladder retraining :)
    InterStim Therapy :eek:
    A Flomax pill in the tank before refuelling :p
