Problems in paradise after tranny swap
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by borgestes, Jul 10, 2018.
  1. borgestes
    borgestes Member
    82
    73
    New York
    I seem to be getting spanked. I had a prius 2010 have the tranny fail after the owner pulled the trailer a couple times too many. I have it all back together and I cannot get it to run.
    https://drive.google.com/open?id=1SMWf6a-tR0KtwWmPmbjHUNlBCCSxAhrh
    This is a link to all the screenshots. I understand they are pretty poor quality but hopefully someone can see something. Any suggestions would really be appreciated cause I cannot figure out what mr computer is unhappy about. It runs for about 8 seconds and shuts down saying check hybrid system.
    I just added a second copy off another phone camera, Hopefully someone can see something that I don't see
    #1 borgestes, Jul 10, 2018
  2. JC91006
    16,482
    8,400
    Are you sure the swapped tranny is good?
    Post the codes you're pulling on the car now
  3. borgestes
    borgestes Member
    82
    73
    New York
    codes are on the link. The tranny came out of a running car, salvage yard. The mg1 numbers look right. I don't know what its unhappy about. Thanks
    swapped coils outside to inside, no change on the trouble codes
    #3 borgestes, Jul 10, 2018
  4. danlatu
    danlatu Senior Member
    533
    1,348
    maryland
    Any sensor/plug that appears to be plugged in, can still have a poor connection. I had my prius die on me 5 miles away from my house. Luckily I had my obdII reader on me. Read it as a cam shaft position sensor. I pulled on it and it was plugged in. Cleared the code and restarted car, code popped up again. I then unplugged and replugged it in, reset code and it has not reappeared since. So bizarre.
    Worth a look to go over all your connectors again. Buying parts from a wrecked salvage prius is what worries me. It is a lot of labor to get it replaced for warranty.
    m.wynn likes this.
  5. JC91006
    16,482
    8,400
    I sold a gen 3 that was running for $2000 last year. The engine burned tons of oil, blown head gasket and had transaxle issue. I didn't bother trying to fix it.
    It probably ended up at a scrap yard and whoever buys the engine or transaxle would have issues
    m.wynn and Raytheeagle like this.
  6. Grit
    Grit Senior Member
    6,148
    4,058
    Wilkes Land
    For no particular reason I just dont feel comfortable when the word "tranny" is used in this context.
    m.wynn, Raytheeagle and JC91006 like this.
  7. m.wynn
    m.wynn Senior Member
    684
    1,226
    Queensbury, NY
    Turd gen P0A0F with momentary start-up/stall is most commonly reported from simply leaving the PCV hose disconnected, fwiw. My personal experience with it kept me in the garage til 2:30 a.m. :cool::rolleyes:...
    danlatu and Raytheeagle like this.
