Problems with catalytic converter guards
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jim Egeland, Jul 31, 2022.
  1. Jim Egeland
    Jim Egeland Junior Member
    Idaho
    I am considering buying a catalytic converter guard for my 2006 Prius. I know of one owner who has had trouble with the guard because it sits lower and she’s hitting it with rocks on a rocky road. I don’t want to get a guard if I have to continually fix it or repair it. Any thoughts?
  2. PriusCamper
    PriusCamper Senior Member
    13,407
    5,413
    Pacific Northwest, USA
    Cat covers are down to as low as $60 range onlineand easier to install and these anti-theft systems are just deterrents not complete protection. So no reason to buy one that's going to catch road debris cause that's way more dangerous over time than you might think.
    52,784
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    Do you regularly drive on "rocky roads"? Unless the springs are sagging, I wouldn't think that a cat shield should sit that low.
    I run one on my 06, and don't have problems on "unimproved" camp ranger roads.
  5. PriusCamper
    13,407
    5,413
    I think that method would actually help hold the sawz-all blade in place and make the cut go quicker not slower... It's not protection, it's assistance.
  6. bisco
    52,784
    i was thinking the chain would move too much for the sawzall to bite
    xliderider likes this.
  7. donbright
    donbright Active Member
    241
    151
    33
    oklahoma
    i can't see this happening. the shield I have is a big flat sheet of aluminum that bolts / rivets directly to the frame, it does not drop down at all. it is basically flush with the rest of the underbody. the other shields i have seen are all flat. i dont see how its possible. if you are running over stuff that is high enough to hit the shield, it's high enough to hit other parts of the undercarriage.
  8. PriusCamper
    13,407
    5,413
  9. Mendel Leisk
    42,271
    The chain wrap has 3~4 layers, locked very tight. I don't think there's any way to get a recipricating saw blade through there, and plenty of chance it would just lock and shake the saw out of your hands.
    Hopefully never get to test it...
  10. PriusCamper
    13,407
    5,413
    My point is the chain acts as a guide that one side of sawzall blade can be pressed against to keep the blade from moving left and right and making it easier to get the cut started, even if the cut starts at a larger diameter of the can instead of the pipe. On the other hand the steel cables placed parallel to exhaust line move around so much when you start the blade on them that you can't get the cut started because the blade moves left and right.
