Problems with Water Pump and transmission 2007 Prius
Discussion in 'Gen 2 Prius Technical Discussion' started by AMT, Nov 17, 2018.
  1. AMT
    AMT New Member
    napa
    Please bear with me because I know very little about cars. I have been taking my 2007 Prius to Dublin Toyota for 10 years. I've done every routine maintenance and repair suggested.
    At the end of September I took my Prius in for its 160,000 mile service and 4 new tires. They told me I had a leaky water pump. I went back 2 weeks later and they replaced the water pump for about $650.
    A week later my car started making a squeaking noise. I took it back to the dealership and they said they'd installed the pump wrong but fixed it and now it was fine.
    A week later my car started making the squeaking noise again. I took it back and they said the belt was loose but they fixed it and now it was fine.
    Yes, you guessed it, a week later my car started making the noise again. I took it back and they said the tensor pulley needed to be replaced but now it was fine. That was another $300.
    Some of the noises went away but one didn't and then I had a couple more, so 3 weeks after the last repair I took the car back and today, after waiting for 6 hours, they told me I need a new TRANSMISSION. BTW they had the head mechanic take it for a test drive and the story the service rep told him about the history of the repairs was completely different than I'd been told. He said at first they thought it was the water pump but it was the inverter? and the belt had become wet and they had to replace it. When I asked him about it he denied it and said he meant the belt had become worn. He said when they replaced the pulley they replaced the belt at that time but there is no mention of that on my paperwork and I was not asked nor did I give consent for that repair.
    I asked why they didn't catch the transmission problem in the last five visits and they said they don't test for that kind of thing. I find that really hard to believe.
    I'm going for another opinion and filing a complaint with the State, but the whole thing sounds fishy to me. Any thoughts are very much appreciated.
    Finally, they quoted me almost $5,000 to replace the transmission which I obviously would not do there. But given I've hardly done any repair to the car and it's paid for, I wonder if it would be worth it to have it fixed. I don't have the money right now to buy a new Prius.
    #1 AMT, Nov 17, 2018
    52,883
    welcome!
    sorry for your troubles. it don't sound a little fishy. maybe not so much deceptive as inadequate.
    regarding the tranny, the price is right for a dealer, nut you may be able to find someone who can install a salvage low mile unit for a lot less.
    if you don't have any trouble lights on the dash, i'm not sure that is the problem. does the car drive okay?
    hard to know much else without hearing the noises. any independent hybrid shoppes out there?
    you are pretty close to luscious garage, avi's automotive and @Raytheeagle if i'm not mistaken
    Raytheeagle likes this.
  3. JC91006
    16,938
    8,647
    I'd say move on from that Toyota service department and find another one. They obviously want to scare you out of your car and into a new one.
    They don't seem to be very honest based on the work performed and explanations given. EVERYTHING they do is logged into your paperwork, that's how they get your money. No free services without paperwork
    Skibob likes this.
  4. AMT
    AMT New Member
    napa
    Thank you, yes, I have a friend who goes to luscious garage so I will go there. I thought that was odd as well, no lights and aside from the noises the car runs fine. Anyway I've reported this to the BAR because I worry they may have damaged my car. I made this timeline which might give more hints. In particular at the last visit the Service Advisor slipped up and told the mechanic the serpentine belt came in soaked and had to be replace. Then he changed his story and said the belt was worn. Lots of mistakes going on.
    8/27/18
    Jonas Woodson Service Consultant
    160,000 (10,000) mile service and 4 tires
    Recommended Replace water pump (found coolant leak)
    9/12/18
    Replace Water Pump
    9/18/18
    Scott Murphy Service Consultant
    Whining noise while engine is running
    (“Performed inspection found drive belt out of adjustment, adjusted belt no more noise”) however I was told at the time that the water pump was incorrectly installed.
    Check lug nuts due to whirring noise on acceleration (verified torque on lug nuts)
    I asked Scott at this visit if the serpentine belt needed replacement, he said no it was fine.
    9/24/18
    Loud screeching noise coming from car
    Called and spoke to Scott Murphy who said it was probably a rock in the brakes, advised to drive around and see if rock dislodged. Drove around and sound went away.
    10/12/18
    William Martin Service Consultant
    Advised that car was unsafe to drive because it needed a new serpentine drive belt idler pulley bearing. Provided with rental car because they said they did not have the part.
    I asked why this was missed at the last two visits and was told it just happened. I asked if it had to do with the belt being loose and was told no, it just went bad after the last visit. I asked if the car needed a new serpentine belt and was told no.
    10/14/18
    ‘Big Al’ Service Consultant
    Picked up car. I asked if the serpentine belt needed to be replaced. ‘Big Al’ told me there are 3 water pumps in the Prius and the one I had replaced does not require a belt.
    11/16/18
    Same whirring noise on acceleration, intermittent rattling and humming noise.
    Mechanic was requested by William Martin to take car for test drive. I began to tell the mechanic the history of the problem and William Martin interrupted me and told him “The car came in with the serpentine belt soaked and needed a new belt and idler pulley.” I told William Martin I had not been advised of this and he said he made a mistake, he meant the belt was worn, not soaked. I asked why the belt had not been replaced at the 3 prior visits if it were worn and he said it just became worn after the last visit. I asked why there was no mention of the serpentine belt on my invoice. He said it was a mistake.
    Was told “Located noise to final drive gears in transmission. Recommend transmission assembly.”
    I asked why this had not been found before and was told ‘We don’t test for these things.”
  5. AMT
    AMT New Member
    napa
    Right, I would never go back there for sure. I hope the BAR can get to the bottom of what they did or didn't do!
  6. bisco
    52,883
    i would write a letter to the owner/manager of dublin as well, give them a chance to make it right
  7. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Are there any lights on the dash?
    Noises can be hard to chase as you are finding out the rather expensive way.
    Your location lists Napa, any reason you’ve driven all the way to Dublin for this servicing?
    I agree to finding another shop as the distance and costs are stacking the deck against a revisit.
    Good luck and keep us posted (y).
  8. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Which water pump was suggested to be replaced?
    Which one did they do, there should be a description and part number on your invoice.
    You can't really install the engine water pump "wrong".
    Whirring noises are NOT due to lug nuts, they did not dig into that at all, so hope they did not charge you.
    So the sound did go away?
    Again, for the $650 you paid them to install the engine water pump (I presume) the idler and serpentine belt should have been included!
    That does not match previous statements, the invoice will tell all what you paid for.
    Again, PART NUMBERS, they do not lie. Belts do not suddenly become worn in 30 days when it has been carefully checked three times since August. What soaked the belt? There is nothing, other than a leaking engine water pump or OIL LEAK that CAN soak the belt.
    Based on what? Lucious Garage has a video posted about transaxle whine in these cars, if this sounds like the noise you have, they may be right that you need a replacement, but completely wrong about why.
    Then why were you charged for testing at all if they do not do it????
    You should ask them just that, which should make them squirm. :p
  9. AMT
    AMT New Member
    napa
    Thank you for helping me with this!
    OK, here we go
    The part number for the pump was 16100-29157-83 for $97.50
    Super long-life coolant part (they call if FP) number 00272-SLLC2 for $36.04
    Labor 508.97
    The screeching sound did go away, but now I wonder if that was the tension pulley failing.
    I said the same thing, the belt and pulley would not go bad all of a sudden, William insisted they do! I figured the same, that the water pump was leaking because the pulley (and possibly the belt) needed replacement all along. I asked William why they weren't replaced in the first place and he said the mechanic only does what the service order says, so if they saw the belt or pulley needed replacing they wouldn't do it or say anything (?!!) Honestly to lie like that with a straight face, I can't imagine.
    Thank you Ray! No lights at all, either when the water pump was supposedly leaking or now. It all started after my 160,000 mile checkup which is a 10,000 mile service. No problems at all with lights, noises or performance before that. I used to live close to Dublin so when I moved to Napa I kept going there, if it's only every 6 months I don't mind and I can have lunch, go shopping and see a movie while they have the car so it's actually a nice day. No way I'd ever go back there, the distance and the craziness are too much.
    That's a good idea, I just don't know what would make it right other than a new car. Even if they give me all my money back I don't know the extent of the damage. I guess I will take it to an independent garage for evaluation and see what the BAR has to say. It really bothers me that they take advantage of women. From now on if someone says there is a problem I want to see it and also get all my old parts back.
    #9 AMT, Nov 19, 2018
  10. 05PreeUs
    1,097
    565
    MSP
    ACK! They charged you MORE than retail for the pump and yes it is for the engine, so that is what "we" thought. You paid DOUBLE what the Lexus dealer charges for the coolant and about 50% more in labor than would be "reasonable" given the time it actually takes.
    The belt does not "suddenly fail", unless it breaks, which can happen but is exceptionally rare. The pulley bearing, yes, they work one minute and not the next.
  11. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    If the pulley bearing was bad the friction could cause the belt to wear prematurely. I saw it happen in a Volvo when the dealer changed the timing belt. Tensioner bearing went and broke a brand new timing belt. Dealer manned up and redid the job for free though.
  12. Skibob
    2,912
    1,505
    Northern California
    Some of those Bay Area dealers are brutal when it comes to pricing.
    Stevens Creek Toyota charged the lady 400 dollars to change the clutch bushing on the 4 Runner she sold me. The squeaky plastic clutch pedal bushing.
  13. AMT
    AMT New Member
    napa
    That would make sense. If they missed the pulley bearing it could have caused the belt to become loose. Do you think it might have caused the water pump to leak again? I don't think the Service Advisor saying the belt was soaked was incorrect, although I'm sure he regrets saying it. I also find it very fishy they didn't put anything about replacing the belt on the receipt.
    Another question I have - if the water pump assembly was badly broken, might it affect the transmission? I had zero problems with the car before they worked on it and I find it hard to believe the transmission would just go like that.
  14. AMT
    AMT New Member
    napa
    I thought it was a lot too! They'd sent me a coupon for 20% off after the repair was already done so I made them give me that refund anyway. I wish I'd never gone to them though, seems like my car might be ruined by what they did. Even when I bought tires there and tried to get their 'we'll beat any deal' thing they tried to get out of it until I argued with them. Bunch of shysters!!!
  15. AMT
    AMT New Member
    napa
    Wow, thank you! That's what I thought about the belt too, that guy was such a liar! I think the screeching sound I heard was the pulley bearing giving out.
  16. Skibob
    2,912
    1,505
    Northern California
    You are probably right about the screeching sound being the pulley bearing. I’m not sure about if it could cause the water pump to leak. If the bad pulley put extra stress on the pump somehow that could be the reason. As far as the water pump causing transmission problems I have to say no. Unfortunately sometimes things go bad around the same time. Has anyone actually checked the fluid level of the transmission or replaced the fluid?
    AMT likes this.
  17. 05PreeUs
    1,097
    565
    MSP
    Naaaa, the WP was "due" by time and mileage, the bearing however, somewhat unusual.
  18. bisco
    52,883
    could the tranny just be a coincidence?
    AMT likes this.
  19. exstudent
    exstudent Senior Member
    2,214
    906
    Torrance, CA
    This is too egregious for redemption. Only redemption is to see people behind bars or hiding their faces from an investigative news camera. Fool me once, shame on you. Fool me six times, shame on me.
    Yes, write the letter to that dealership and to Corporate Toyota too. Let both parties know you have logged your complaint with California's BAR (Bureau of Automotive Repair). Rest assured, unscrupulous repair shops do NOT like it when customers complain to a Regulating Government Agency. The letter should include the scary fact that OP has been going here for the past 10 years; not a one time customer but a long time customer. The letter to Toyota should include the same but clearly state that the criminal events have soured you from Toyota FOREVER, and your future vehicles will be anything but Toyota/Lexus/Scion. That statement will absolutely get a response from a higher up from Toyota; f'n criminals just cost us a proven loyal customer. I can seem corporate getting involved to ameliorate the situation.
    If corporate should offer financial assistance, OP should accept it but state: pay the service bill from Luscious Garage, not the Dublin criminals or any other dealership. This is the only way to redeem the brand, but not the criminal service departments. OP has paid for 10years of significant leverage and can use it effectively.
    OP can further accentuate his position w/ Twitter. There is probably near universal hatred of dealer service departments.
    #Toyota Service Robbery
    #Toyota Stealership
    #Toyota Service Thieves
    #Toyota ripoff
    AMT likes this.
  20. AMT
    AMT New Member
    napa
    Thank you everyone, I can't tell you how helpful this has been. I will have to look back at my records to see when they last checked the transmission fluid, but 2 weeks before the water pump replacement I had a 10,000 mile checkup. You'd think when they told me the tranny was bad they would have mentioned if the fluid was low but honestly I don't expect much from them at this point. One of the things I wanted to find out from the experts here is if the water pump leaking or non-functioning could affect the transmission and it sounds like no. I had the serpentine belt replaced before but not the water pump or the pulley so I think that was probably due but feel like they should have recommended that and the water pump at the service so this kind of thing wouldn't happen. I got a call from the BAR yesterday so I will call him back this morning. Thanks for the ideas about letters and tweets! I posted on Yelp and FB already but I'm going to slam them with complaints. My friend also sent me contact information for some news outlets she used when her identity was stolen. Thank you all you very kind people and have a happy Thanksgiving. I will be working (I'm a nurse) but thinking about all the good people out there instead of the bad ones!
