Procedure to remove exhaust manifold
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sean F, Jul 29, 2017.
  1. Sean F
    Sean F New Member
    Ma
    Hello,
    Can anyone please tell me the procedure to remove the exhaust manifold? I have copies of the repair manual, but need help following which steps in which order.
    I'd really appreciate some help. Screwed up the wife's Prius and now I need to fix it.
    What did I do? For the curious I cut the spring bolts between the cat and the manifold not realizing that the nuts on the backside are welded - Doh!! Drilling out the bolts seems impossible - believe me I have tried. So I am resorting to looking at removing the manifold to make a proper repair.
    Thanks
    Sean
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Your in the wrong forum post this in the maintenance and repair forum
    You will get more responses.
    Not sure if I understand is there a nut or a bolt on the manifold side?
    If it's a nut just leave it and drill the nut hole out larger and put a bolt thru and then a nut.
    If it's a bolt that's more difficult I would drive the car to a muffler shop they see this a lot and can heat up the bolt and knock it out.
    You need a pro torch to do this a map gas bottle will not have enough heat.
    I would try anything other than pulling the manifold sometimes that goes really bad and if you snap off a bolt in the block your screwed.
  3. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    Yeah I agree. Should still get a replacement spring and bolt, but just put a nut that will fit it on the backside.
    iPad ?
