Professional EGR Cleaning Resources
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mendel Leisk, Oct 5, 2022.
  1. Lottamoxie
    Lottamoxie Member
    435
    64
    Southeast US
    I recently spoke with a Prius mechanic and that's what he works on: Prii. He's not located in my area. Anyway, I asked him about EGR cleaning and all the other bits involved as well for my Prius that has less than 40K miles.
    He said, "I would not consider cleaning the egr until 100k miles. The last 2 EGR cleanings I did (both in 130k range) were dirty, but neither was close to being clogged. They both could have easily gone 150k miles before their cleaning. No, you do not have to clean the EGR every 50K miles, that's not necessary IMO."
    52,844
    it shows how varied the experiences are
  3. adrtho4
    adrtho4 Member
    71
    26
    Houston, TX
    Good insight here. My Prius is 160k. Just cleaned it for the first time. Considering buying an ultrasonic cleaner to really get is deep cleaned. Will keep this in my notes.
  4. Mendel Leisk
    42,343
    When deciding an EGR cleaning interval, having a garage, semi-complete tool collection, being comfortable with routine maintenance, and being retired/bored, “may” colour my judgement. Our ‘10’s my test subject. ;)
  5. Bill Norton
    Bill Norton Senior Member
    2,243
    753
    MONW, Ks.
    2019 Prius
    L Eco
    Don't go over board....
    The 'pinch down spots' are in the tiny individual intake ports.
    Those can be made new in a few minutes with a small brass rotary brush on a drill. After the intake manifold is on the floor, that is....
    The rest of the system can handle the patina of crud on the walls of the passages.
  6. Lottamoxie
    Lottamoxie Member
    435
    64
    Southeast US
    That's a vital set of facts that should be disclosed, whenever you're giving your opinion to other Prii owners about the EGR and related systems.
    It's not standard protocol for a Prius owner to be cleaning the EGR before 100K miles, and certainly not every 50K miles. That you choose to clean your EGR system often, is not something recommended by Prii mechanics, and advising other owners to clean their EGR systems often, which isn't necessary, increases maintenance costs for fellow owners.
    Bill Norton and Mendel Leisk like this.
  7. ASRDogman
    ASRDogman Senior Member
    8,063
    4,086
  8. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    Had anyone tried removing the EGR completely like Prius sold in Brazil or other parts of the world? It probably solves the cleaning completely:LOL::LOL:
    Bill Norton likes this.
  9. adrtho4
    adrtho4 Member
    71
    26
    Houston, TX
    Yeah, I'm not out to make it 100% new straight from the factory clean. I used just what you suggested, a small brass rotary brush and my drill and got the bulk of the crud out.
  10. johnHRP
    646
    189
    KA, DE
    Excel
    I will focus on the EGR valves, pipes, and intake manifolds. The cooler is too much time to fidling around if it is not clogged.
  11. Mendel Leisk
    42,343
    I'd get an opinion from Tampa Hybrids as well.
    Toyota's NEVER going to conceed they messed up with third gen EGR. Or the low-friction piston rings. So here we are.
    All you can do is tell people how it is, leave it there. If they see what's involved, and/or the $'s to have a competent pros do it, and get cold feet, that's their business.
    fox and grapes?
    #211 Mendel Leisk, Jun 10, 2025
  12. Mendel Leisk
    42,343
    The EGR cooler may have trouble cooling, with that patina of crud...
    Same story. Curious too, how you determine it's condition, without removing it.
  13. Bill Norton
    2,243
    753
    MONW, Ks.
    2019 Prius
    L Eco
    And even it it is starting to clog a bit, at least it will decrease the EGR flow EVENLY.
    The head gaskets failing near the #1 and 2 cylinders is due to the UNEVEN flow of EGR gasses, theoretically.
    The 1 and 2 ports are farthest from the source of the flow and have more time to cool and condense the crud in those small intake ports.
    If the overall flow gets restricted enough,,,, there's a code for that. Correct?
    The system compares MAF and MAP sensors and see the lack of EGR effecting the MAP reading.
    Is this correct?
    OK, then what happens when the EGR gasses are 'hotter than expected'?
    Would the plastic near the EGR pipe start to show signs of melting?
    Clamp a thermocouple on the 90° EGR pipe and try to get temp data. Maybe before and after your spotless cleanings. good luck....
    I see some other engines with insulation wrap on EGR pipes trying to keep the EGR gasses as hot as possible.
  14. ChapmanF
    19,016
    The criterion johnHRP mentions is "if it is not clogged", for which the car's routine EGR flow test result would seem to give a pretty direct answer.
    That is, a good flow test result is a pretty direct answer. A lower flow result could be lower because of clogging somewhere else, or because of a rut in the valve rotor. On the other hand, if you've checked and there's no rut and the other stuff isn't clogged, then your low flow result can be pinned on the cooler.
    That doesn't directly address Mendel's concern about patina reducing cooling, which johnHRP might not be as concerned about. How concerned about it one should be seems an open question. Bill Norton's suggestion of comparing clamp-on thermocouple readings before/after cleaning seems like a sensible approach; I haven't seen that anyone's posted such results to date.
  15. Mendel Leisk
    42,343
    A little off-topic, but someone on Reddit just used these guys for a head gasket repair, apparently went well, and good price:
    Hybrid Auto Repair
    Uxbridge, MA
    (USA)
    Reddit LInk
    Google Link (reviews, full address and contact info)
  16. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    I have a better idea..... get rid of it......................before the REAL PAIN STARTS....................
  17. Mendel Leisk
    42,343
    phttt
    Good avatar. Your's no more?
    Tim Jones likes this.
  18. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    I got rid of that junker 4 years ago.... best thing I ever did......... I have ICE (toy) and it's way better for low cost super high miles........
