Program new Non-SKS key without original on 2012 Prius
Discussion in 'Prime Technical Discussion' started by Kyle Wellmerling, Jan 9, 2018.
  1. Kyle Wellmerling
    Kyle Wellmerling New Member
    Ithaca NY
    Hello, my key fell out of my pocket and has been lost in the snow. Dealer wants $466 to replace it and program a new one. Also it'd cost $120 to tow the car there, so I'm looking to avoid paying $586.
    I'm fairly confident my car is Non-SKS (I couldn't just have the key and open the door to get in, and there's no black patch on the door handle).
    What I've found by googling is this:
    1. Successful SKS Reset using Mangoose cable and used Keyfob registration | Page 2 | PriusChat
    ^this seems to be only for reprogramming an SKS key w/o an original, and
    2. Finally! How to program a non-SKS key/fob. Detailed! | PriusChat
    ^This seems to be for reprogramming a non-sks key w/ the original.
    Unfortunately I don't fit into either of these groups.
    If someone had information to help me, it'd be greatly appreicated.
    -Thanks
    49,490
    welcome!
    i don't think they made non sks gen 3 (2010-15) be careful reading threads from gen 2, it is different. but idk if you can or not. try contacting some locksmiths, the better ones have a handle on these things.
    you have package four? should be 3 door sks i would think. there are small grooves on top of the door handle you touch to lock, and placing your fingers inside the handle unlocks. the rubber pad was gen 2 (2004-2009)
    all the best!(y)
    49,490
    duplicate
  4. Kyle Wellmerling
    Ithaca NY
    Whoops, I have the II, I filled that out wrong, so I maybe I do have the SKS system, in which case I can try that first poster's thing.
  5. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    You have a 2012, though so it is a Generation 3 Prius.
  6. Prodigyplace
    11,696
    11,318
    Central Virginia
    Website acting up again? :(
  7. bisco
    49,490
    must be, it didn't show posted after a few minutes, so i hit it again.:rolleyes:
    Prodigyplace likes this.
