Programming a new fob
Discussion in 'Gen 4 Prius Main Forum' started by PVAFam, May 26, 2017.
  1. PVAFam
    PVAFam Junior Member
    Houston
    Three Touring
    Car only came with one key so I searched around for anyone who said they had done this and didn't find proof, I thought I should post that it's woking fine with a new OEM key and the mini VCI that I got from eBay. Same procedure as some videos on the gen 3 cars. Also setup stuff like the remote window down and all doors unlocking with touching the handle.
    52,373
    congrats and welcome! how did you get a gen 4 with one key?
  3. PVAFam
    Houston
    Three Touring
    Thanks, it was a repo so I guess they had to make a new key for it, the blade in it wasn't cut at first. Nav SD was missing but got the dealer to give me one of those, still need the little door that covers it. Don't have a cargo cover, did they all come with one?
    RCO and bisco like this.
    52,373
    i think so, did you look under the floor?
  5. PVAFam
    Houston
    Three Touring
    Yes, there is a spot for a beam in the styrofoam blocks, but no cover.
  6. Prodigyplace
    12,669
    11,828
    Central Virginia
    Welcome.
    I believe your car had the foldable cover that had a wire frame around the edge and comes in a storage bag. There are two hinge mounts behind the rear seat. The hatch end fastens with strings to the hatch and the car so it raises up when the hatch is opened.
    PVAFam and RCO like this.
  7. Prodigyplace
    12,669
    11,828
    Central Virginia
    #7 Prodigyplace, May 27, 2017
  8. bisco
    52,373
    the 'visual tables' sticky thread in the gen 4 main forum shows which package gets which cover. looks like they all get one standard, and the 2 gets the 'one piece foldable fabric'.
  9. Prodigyplace
    12,669
    11,828
    Central Virginia
    I must have misread then.
    To be sure behind the back seat does the car have the hooks for the foldable cover or the sockets for the rollup one?
    EDIT I looked again. The way I read the table the 3T and below have the foldable cover. The OP has a 2016 3T.
  10. bisco
    52,373
    i wrote foldable?
    RCO likes this.
