Road Noise
Discussion in 'Gen 4 Prius Main Forum' started by smalltimeart, Feb 24, 2017.
  1. alexgrigori
    alexgrigori Active Member
    163
    109
    Technology
    Yes, if the ICE is off the car is very quiet - confusingly quiet, I'd say, once, in the beginning, I left the car on parking without shutting down :).
    Air conditioning is surprisingly quiet too, even on max speed.
    #41 alexgrigori, Mar 3, 2017
    Absolu22 likes this.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I was going to suggest you were, and I mean this kindly, 'supersensitive' but if you find the air blower quiet even on fast setting. Well, that dispels my idea. Perhaps you're just subconsciously comparing various noises.
    kithmo likes this.
  3. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Maybe you're more susceptible to certain frequencies, I know I was with the Gen 3, there was a certain frequency of road noise that I found very tiring on that.
    RCO likes this.
  4. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    You've heard my wife then? :ROFLMAO:
    C Wagner, kithmo and Prodigyplace like this.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    She can't be as bad as my mother-in-law, she's like having a rear bearing, drone, a blowing exhaust and stones hitting your windscreen all at the same time.
    C Wagner and RCO like this.
  6. ePWR
    ePWR Member
    131
    137
    PRIUSchat
    I agree that the various types of pavements can increase/decrease the road and tire noise. It's not too bothersome. I appreciate all the reports posted about the Michelin Defenders and Michelin AS tires. I will consider them in the future.
    C Wagner likes this.
  7. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    And the speed you're doing. I had someone in the car the other day, there was a long red traffic light. He commented after a minute or so at idle "isn't it quiet". I flicked it into EV Mode and quietly accelerated away gently to rub it in.
    At motorway speeds, I don't think it's any quieter than my previous cars which were diesels, what with wind and road - and my CD noise.
    RCO likes this.
  8. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    My rental car this week in Detroit that I picked up today is a 2016 Gen 4 Two. First time I have driven a Gen 4 and I am really enjoying it. However I very much notice the road noise compared to my Gen 2. I suspect the road noise level may be the same as my Gen 2 but because overall the Gen 4 is much quieter, less wind noise, and engine noise is practically non-existent, it seems to make road noise stand out more noticeably. It seems like it is mainly coming from the rear, even though I have the rear seats up. The rental car for some reason is missing the tonneau cover, maybe that is part of the reason as I have heard that the tonneau cover helps reduce road noise a little bit. Another factor is on my Gen 2 I am currently running Michelin Premier A/S which are the quietest and best handling tires I have ever used on my Gen 2, the only downside is there is about a 2 mpg hit in gas mileage. But after ten years of driving efficient tires I decided to splurge a bit this time around. The rental Gen 4 two that I am driving this week has Bridgestone Ecopia.
  9. alanclarkeau
    7,045
    7,593
    The tonneau cover might be under the boot/trunk floor - there's a place designed for it to go there - mine lives there most of the time.
  10. Tideland Prius
    16,683
    The Prius Two would have the fabric tonneau cover so it was probably chucked away by the rental company or misplaced. (The cover comes in a bag so they may have put the bag containing the foldable tonneau cover somewhere else)
    RCO likes this.
  11. alanclarkeau
    7,045
    7,593
    Mine is just a floppy roll-up fabric cover - more trouble than it's worth most of the time. There's a cavity just made for it above the spare wheel.
    upload_2017-5-9_15-33-30.png upload_2017-5-9_15-33-54.png upload_2017-5-9_15-34-41.png
    RCO likes this.
  12. Tideland Prius
    16,683
    I thought that was vinyl?
    I was referring to the mesh fabric with a wire frame.
    It opens up like a sunshade and attaches at 6 points (you can see 4 of them with the strings there and the last two are at the front of the cargo area, behind the rear seats (where your tonneau cover bar would sit)
    alanclarkeau, RCO and Prodigyplace like this.
  13. alanclarkeau
    7,045
    7,593
    Yes, mine is a vinyl type fabric. It's really useless compared with the type you showed. I had your lift-up type on all 5 or 6 previous hatchbacks. I was told it wasn't available on PRIUS - but just looks like TOYOTA Aust decided on the "useless" type.
    RCO likes this.
  14. Prodigyplace
    12,718
    11,850
    Central Virginia
    In the US, it depends on the trim level. The lower trims have the lift-up cover and the higher ones have one like yours.
  15. Tideland Prius
    16,683
    Those were typical of the liftbacks and fastbacks. I'm unsure of the North American preference for the roller-type tonneau cover. I guess it's easy to retract. The wireframe mesh is a bit more clumsy to pack up if you need the extra height.
  16. Prodigyplace
    12,718
    11,850
    Central Virginia
    I just sit my mesh one on the cargo floor if I need the extra height.
    If the cargo might be messy, I have also placed it behind the front seats. That would not work with rear seat passengers though.
    Tideland Prius likes this.
  17. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    Best solution is Increase the JBL volume and start grooving, road noise is gone.
    alanclarkeau likes this.
  18. Prodigyplace
    12,718
    11,850
    Central Virginia
    ...which leads to loss of hearing, which leads to hearing aids, which leads to emphasized high frequency noise.
    Been there, done that :(
    Peter the pickle and RCO like this.
  19. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    There is an entire section somewhere in this Priuschat site that had one guy completely insulating his Gen III. He even gave you the results and the difference it made. Can't remember the name, but it was a pretty lengthy install that included photos.
  20. smalltimeart
    smalltimeart New Member
    22
    Four Touring
    ok it's been a while but using a dB meter i managed to get the following readings. Each footwell is around 95dB peaking at 100dB while the cabin averages between 80-85dB
    RCO likes this.
