Programming Ourselves?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by rachaelseven, Jul 25, 2009.
  1. xenonrider
    xenonrider Junior Member
    76
    SoCal
    10Prius.. thanks for taking the time to program my Prius. I really appreciate it:thumb: Now, I can enjoy my Prius even more :D
  2. 10Prius
    10Prius Junior Member
    Los Angeles
    No problem. Glad I could help.
    No more annoying multi-beep reverse and seat belts warning.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    Bump, has anyone else successfully used the $295 Drew Tech cable with their Gen II or Gen III Prius?
    Thanks.
  4. AbuS3ood
    AbuS3ood Member
    113
    Jordan
    its for 485$ and working perfectly so far with Techstream, i have it from two years...
  5. astrand
    astrand PHEV Guru
    33
    Linköping, Sweden
    I've used both the Drew Tech Mongoose MFC as well as the cheaper Mangoose cable for occasional health checks etc. Has worked fine. Recently, however, I've tried more features of Techstream, but got some errors. With Techstream 4.21, the "Communication Bus Check" only listed 3 ECUs. Customizations didn't work at all: Couldn't find anything to customize.
    After upgrading to Techstream 6.20, it works slightly better. I was able to turn off the reverse beep, for example. But there are still systems under "Customization" that lists nothing to customize, and on the "system selection menu", there are several ECUs marked with a star, indicating "ECU not supported or responding".
    Any ideas? I do not have access to the Drew Tech cable at this time, so I cannot verify if the problem is caused by the cheaper Mangoose cable. Has anyone been able to find updated drivers? The reference is to j2534.cn, but it contains nothing but ads.
    Or, perhaps the problem is that I've selected the wrong model? I can select between "S/D, Others" containing China -1112, China 1112-, Korea -1009, Korea 1009-1112, Korea 1112-, Others -1009, Others, 1009-1112, Others 1112. Or, I can select "W/G" with options Radar Cruise and Others. I assume the numbers denotes months/years, but what about "S/D, Others" versus "W/G"?
  6. AbuS3ood
    AbuS3ood Member
    113
    Jordan
    Dont waste your money on clones,
  7. Philatc
    Philatc Pushing Tin
    137
    46
    Calfornia
    Can you use the techsteam to unlock the nav?
  8. will I am
    will I am New Member
    17
    cali LA
    not sure if anyone asked but would this work?
    i was able to disable the seatbelt/backup beep with elm327 android app and would be fine with it if codes were readily available but sadly its not or hard to acquire. does one have the full set of code?
    thanks
  9. stripedrex
    stripedrex Junior Member
    29
    Smithtown, NY
    Looks like some basic ecu functions you guys can manage. You guys able to change engine related settings? Timing, idc, etc? Also turning off codes? For example I heard an intake will throw cels, prob bc air coming in is past ecu thresholds for the o2 sensor? It'd be nice to tune this type of stuff out. Or more aggressigvely tune properly for e85 =).
    Samsung Epic ?.
  10. propman07
    propman07 Junior Member
    Just a data point here.....I've got a 2012 Prius Option 4. I tried the instructions found at a link I found on this site to change the multiple backup beeps to a single beep. They did not work. I guess that I'll have to live with it for a while, or take it to the dealership to see if they will be able to make the changes for me. Thanks. I will post the link when I am able.
  11. snijd
    snijd DIY or die
    243
    52
    PNW
    The strange thing about this item is the lack of reference to J2534, the protocol for the Prius and other newer Toyotas. Perhaps just an oversight, but this is a glaring omission.
  12. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    How about programing the DRL's to be activated for gen 3 US version? :cheer2:
  13. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Check in this spreadsheet that Vincent created. It has the codes you're looking for (well, at least some of them).
    http://priuschat.com/forums/obdii-a...us-custom-pids-torque-app-10.html#post1499065
  14. will I am
    17
    cali LA
    try using the bluetooth odbii its 20 bucks on ebay. you can get the free elm327 and torque app at the android market.
    it took me less than 3 min to end the beeps. one of forum member written a blog about it. the seat belt part is the same just follow the pattern.
    thanks for the replies
    ------ Tracksyde
    i looked though this spread sheet but does not have the one ones i want. e.g. auto light shut off. but i will defiantly play with it :D
    -----snijd
    well looks like i will get it just to see....
    if it does work... i wonder if i turn on the hyperterminal and set it to the port used, will it show the query? if so that would be awesome! would defiantly contribute to the torque app.
    Customizable Parameters <---- some of the stuff you can do
  15. propman07
    That is the link that I was trying to add to my post, but I'm still too new. I followed the procedure listed, but it did not work for my 2012 Prius. I could connect to the OBDII using the Torque app, as well as an ELM327 app that the article talks about. When I tried to enter the codes, it returned with an error message. I ended up sending the OBDII back to Amazon.
  16. Rashid K
    Rashid K Junior Member
    10Prius I need your help please!! My keys were stolen from the gym and I am now using my spare :(
    (not to mention they went in my car and stole my garage door opener, house keys and registration card with my home address!!!!)
