Programming Prius key fob
Discussion in 'Gen 2 Prius Main Forum' started by Jon Webb, Jan 8, 2024.
Tags:
  1. Jon Webb
    Jon Webb New Member
    Philadelphia
    I wanted to post about my experience programming my 2005 Prius key fob. I read a lot of the (sometimes contradictory) information about programming them and I think I can clear some things up.
    First, to get the right fob from eBay or whatever, all you have to do is call the parts department of a Toyota dealer and give them your VIN. They can give you the part number and you can then search for that.
    Once you have that you should be able to program it using the "chicken dance" (there are numerous videos and written guides) to unlock the car if you also have a working key. At worst you'll need to erase the memory of the Prius if you have too many (lost) keys stored there. You can always add back any keys you still have after erasing.
    The key memory is in the car, not the fob. Nothing in the fob "knows" that it's connected to a car. The fob just blasts out a certain ID, which the car either accepts or not. There's no such thing as "virgin" fob or whatever. Any fob, new or used, that is the right part number will work.
    When it comes to starting a car, though, things are more complicated. The car can store up to five "master" keys (codes for starting the car), and there's no way to erase them without the help of an auto locksmith. This is why people often can't program the car to start with a new fob–all five slots are used up. When this happens, the "chicken dance" seems to work right up to the end, but the car never accepts the new key (the red icon on the dashboard never stops blinking). And there doesn't seem to be a way to tell how many key slots are in use.
  2. Tombukt2
    Tombukt2 Senior Member
    13,860
    2,519
    Durham NC
    And then at the end of this year is when you need to get seed codes and all of this kind of nonsense to make it all happen again That's why it's important to get at least one original fob when you buy the car or get ready to have a bunch of fun.
  3. Frontporch
    Frontporch Active Member
    552
    128
    Nj
    I have a need to program a second key for my newly acquired Prius. I have a spare factory key from another Prius I no longer have and want to make that work with the current Prius. I hope to manage this with Techstream... will post back success or failure.
    I have SKS. Just noticed the Key Programming sticky thread... 37 pages !! wow. TL;DR. will check out later to see if TechStream was addressed/used
    #3 Frontporch, Jan 10, 2024
    Tombukt2 likes this.
  4. Frontporch
    552
    128
    Nj
    I tried with tech stream and it told me I had 2 of 5 keys registered. I have one working key so I used the function to clear all keys (less the one I have). That function left me with 4 keys left that I could register.
    the registration process fails for the other key but it was simple. Press lock on the good key and within 30 seconds hold lock+unlock on the new key for 1 second and then lock on the new key. Simple but it didn’t register
    I need to investigate one requirement which asked for the following to be true:
    Immobilized codes have been registered
    Power engine switch is ON(IG)
    Smart cancel function is off
    not sure if any of those were OK. I had the car in ACC (2presses). That alone may not be what was expected.
    After searching around a little bit looks like smart cancel indicates that the sks system should have been turned off using the button under the steering wheel. Not sure how to register the immobilizer code of the new key. Probably needs to be inserted in the slot at some point
    #4 Frontporch, Jan 10, 2024
  5. dolj
    dolj Senior Member
    8,646
    4,396
    Wellington, New Zealand
    Two presses of the Start button (with foot off the brake) is IG-ON. One press is ACC.
    If you are using a used fob you need to reseed the car to use it.
    If you want to use the process you used the fob needs to be brand new and never added to a car.
    I'd expect that the SKS disable function should be off (button in out position) to be able to add a new key, but I could be wrong.
    #5 dolj, Jan 16, 2024
    priumium and Frontporch like this.
  6. Frontporch
    552
    128
    Nj
    I did more digging and I think I understand what my options might be
    I may be able to use tech stream to have the Prius recognize the second key’s immobilizer code that would let it start the car if it is placed in the key slot. I would have to use the metal cut key to lock and unlock because neither keyless entry or sks would be working
    I would have been able to setup the second key for the Prius if it was never assigned to a different car either with a chicken dance or by using tech stream. In that case a Virgin key from a dealer would work ($350 locally) I have also found a service on eBay that will virginize the existing second key and mail it back to me in a state similar to a new key for $18 + shipping
    Finally another option is to do a reset of my keyless entry to act as if the system was new and ready to accept multiple keys. For that I would need tech stream and a cable good enough to run a tech stream utility to provide a new externally generated code based on my VIN and a long character sequence provided by tech stream.
    the code I need to provide can be calculated by online services that sell tokens that can be used in their “calculators” to generate that code. Tokens appear to be sold for $10 or 5 tokens for $25. In summary I could run this sks erase and reset using tech stream and then follow a procedure to generate a code and get the smart key system into a state where all keys could be added easily. I would then add both of my keys (existing master and second used key) again and both should have full sks capability
    found the instructions online that go through the process using techstream for resetting the smart key system to register all keys:
    https://www.rav4world.com/attachments/instruction_pass_code_calculator_eng-reduced-filesize-pdf.44034/
    #6 Frontporch, Jan 17, 2024
  7. cdmTX
    cdmTX Junior Member
    16
    Wow - I think this is what happened to me! So I need to go to an auto locksmith?
  8. Tombukt2
    13,860
    2,519
    Durham NC
    Yes an auto locksmith that is older fella and experience with transponder chips and keys He will be able to fix you up very reasonably If you were to have an extra fob that matches your system silver or black whatever it is that might go a long way to help you but now they can be bought in the aftermarket the programmable type for the car that fits in the slot and all of that for $30 that sort of thing there are workarounds no problem You don't have to spend $500 at the dealer or $300.
  9. Tombukt2
    13,860
    2,519
    Durham NC
    But some kid with a computer say some $130 is going to try and charge you $350 because of what you may or may not know and they'll stand hard on that well I have to this and I have to that yeah all that.
  10. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    So question. My 08 was acquired from the original owner and from what I know, there was only 2 keys with the car.
    I recently got a used key fob off marketplace and decided to mate it to my car and tried the methods on YouTube using the key in IGN 5 times and open/close door 6 times then replacing key to new (used really) one i bought and wait for the car/key light to stop blinking. Issue is, my car/key light never stops blinking from the beginning and according to this thread the reason may be due to the car having 5 keys stored already... so I'm confused as if that's my issue as there is no way to tell original the key does NOT work.
    I ensured the replacement key I have is same model MDL B31EG as my current one making the replacement key a SMART key and not just the regular key.
    Any help would be appreciated.
    #10 PriuSocal, Oct 19, 2025
  11. Tombukt2
    13,860
    2,519
    Durham NC
    Original no work ? How the car starts and run? Or it doesn't?
  12. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    Original works fine. Just wanted a 2nd key fob to keep at home in case of an emergency.
  13. dolj
    dolj Senior Member
    8,646
    4,396
    There's your problem right there. To use this method the new key really needs to be a new key, never been used before. A new to you used key won't work.
    You can get a used key to register, but you have to go through the 'All Keys Lost' procedure.
  14. Tombukt2
    13,860
    2,519
    Durham NC
    Is that really correct shiet. I didn't think so. So you're doing the chicken dance with a brand new never used fob? Weird. Luckily I've never had this problem but I'm about to play around with a vvdi key tool in the very near future. My local lock smith has the tool to clone a remote or fob to any number of styles UHS supply sells the stock number discussed above for 59 and returnable.
  15. lexidium
    lexidium Active Member
    304
    144
    manchester
    That's not universal. I wrote off my old Prius and bought one with only one key. I kept one of the keys from the old Prius (same year) and used it to create a new one which does everything. . . . No all keys lost proceedure.
  16. dolj
    dolj Senior Member
    8,646
    4,396
    Not SKS, then?
    Brian1954 likes this.
  17. lexidium
    304
    144
    manchester
    That's true.
  18. Tombukt2
    13,860
    2,519
    Durham NC
    If it's an SKS key and an SKS car and you have another remote SKS silver etc . Then it should program up no issue . Unless it's defective
  19. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    Dolj: I dont believe your info to be correct as most of the videos of the chicken dance show previously used remoted (mainly ebay bought) being paired to existing keys.
    Tombukt2: My car is SKS (smart) with SKS key and the “used” key is also SKS from an SKS car. I am not sure how to tell if its defective as red light comes on when buttons pressed. I have read as mentioned in my initial post that when the red car/key light keeps blinking from the beginning and never stops it could be due to the car alrady having the max allowed SKS key programmed to it already and does not allow more than 5.
  20. dolj
    dolj Senior Member
    8,646
    4,396
    That might be true for a non-SKS car, but it is not true for SKS.
