"Programming" the traction battery?
Discussion in 'Gen 2 Prius Technical Discussion' started by MattLTH, Jan 8, 2019.
  1. MattLTH
    MattLTH Junior Member
    Salt Lake City, UT
    In January of 2018, my 2007 Gen 2 (125k miles at the time) had a traction battery fail. I found a mechanic shop on Yelp that was rated very highly and had them replace the battery with a Toyota factory battery. When I picked it up, the mechanic said that they "programmed" the battery. I'd never heard of that. I asked if he meant programming the car's firmware, and he reiterated that he programmed the battery.
    Since then and now at 138k miles, the mileage hasn't improved that much, and the SoC showing on the ScanGaugeII never seems to climb above 58% (unless I'm traveling downhill and using a lot of regenerative braking), nor does it go below 40% (unless I'm hillclimbing.) The old (original) battery had a wider operational percentage, regularly 30-70%.
    So my question is: Is programming the battery a real thing? If so, is it possible he did it wrong or installed a version that doesn't use the battery as much?
  2. JC91006
    16,939
    8,647
    How do you know he even put in a new Toyota battery?
    There's no programming involved
    Skibob and Raytheeagle like this.
  3. MattLTH
    Salt Lake City, UT
    Thanks, JC. Good question. They provided Toyota paperwork with the serial number and warranty coverage, so I feel confidant they did install a brand new factory battery.
    As for the programming, I'm troubled to learn that was BS. I'm going to have a word with them about that.
  4. brdmb
    brdmb Junior Member
    17
    Ohio
    Can the firmware be upgraded on the battery ECU (control computer)? If so, I'd call that "programming the battery"
  5. JC91006
    16,939
    8,647
    No
    Raytheeagle likes this.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    And immediately after programing the HV Battery, he installed new muffler bearings.
  7. Prodigyplace
    12,720
    11,852
    Central Virginia
    What about the blinker fluid? Judging by the way other drivers act everybody needs more. Very few drivers use those blinkers trying to conserve their fluid.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Having driven it a year and going 13,000 miles, I doubt that you have much recourse with the shop anymore. But I'm suspicious, too, that it's not a new battery. It's not hard to open it up and check the numbers. That should give you what you need to determine its lineage.
    Prodigyplace likes this.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Compared to the mileage figure from when ??
    A drop due to a bad traction battery usually is rather dramatic: a substantial drop suddenly.
    A long gradual drop in mileage is probably due to other factors, not the least of which might just be AGE.
  10. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    The old battery had less capacity than your new battery so the range would tend to be lessened with a new battery. You say the mileage did not go up that much, how much is not than much and what are you getting? Perhaps someone who owned a new 2007 could comment on how your battery is behaving.
  11. jerrymildred
    11,517
    14,171
    Tampa, FL
    I don't know about new, but my wife's "07 with the original HV battery was doing about 48 mpg before I killed it. (long story documented elsewhere) Now, with a 2015 battery, it's around 49 mpg. And she does no hyper-miling. Just a sensible driver.
  12. bisco
    52,891
    what are you getting for mpg's measured by the tank at the pump? i suspect you may be over reacting
  13. scargi01
    scargi01 Active Member
    785
    58
    Missouri
    I have replaced a battery with a used one, and also replaced individual cells in a battery. In both cases the mileage remained the same as before the failure, not higher or lower.
