Project: Add Dynamic Radar Cruise Control
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by galileofigaro, Nov 15, 2018.
  1. galileofigaro
    galileofigaro Junior Member
    37
    2015 Prius Plug-in
    Can you add Dynamic Radar Cruise Control to a 2015 Prius Plug in?
    I mean installing the radar, replacing the steering wheel control switch and connecting special cables and switches.
    We are talking about a $1500 project, at least, but is this feasible?
    Thanks to all!
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    It seems theoretically possible to me, but it would be a massive undertaking and probably really expensive even as a diy project. I'll wait eagerly to see if some intrepid soul has blazed that trail yet. ;)
  3. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    You could add these things, but what do you connect them to? You need to start by finding out what makes the decisions and issues orders to the drive train. Do these parts talk to each other via the CANBUS? If so, how do they physically tie in? Oh, and it's $500 for the radar transparent hood badge. You could use a piece of lexan instead if you don't mind losing the logo.
  4. padroo
    padroo Senior Member
    2,763
    2,253
    I remember older cars having all the plugs in the wiring harness and all you had to do was plug in what you wanted. I don't think it has bee that way for a long time.
    Like was mentioned all the modules in the car talk to one another and my guess is there would have to be some new programming done to make it work.
  5. kenmce
    1,552
    525
    NY
    For something like a light or a radio, that worked fine, and mostly still should.
    I assume he is hoping that the programming is already in there somewhere and that all he has to do is find it and tell it "Giddyup". This might be the case, he needs to research it.
    jerrymildred and padroo like this.
