Project lithium 2013 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by johnerh, Oct 23, 2022.
  1. PriusCamper
    PriusCamper Senior Member
    13,411
    5,413
    Pacific Northwest, USA
    If someone else rotated your tires and reduced tire pressure or got your tires confused with someone else that could do it. Also right now it's only 45' F in Los Angeles which alone takes 6 to 8 mpg away.
    More to the point, you're paying too much attention to your MPG, which is usually when inaccurate measurements happen. Calculate miles per tank by hand and compare it to the car's calculation per tank if you want to ensure you're within the range of accurate.
    johnerh likes this.
  2. ASRDogman
    ASRDogman Senior Member
    8,047
    4,078
    Rotate them back. (y)
    If your mpg improve, you know that's what it was. If it doesn't change,
    it's something else.
    johnerh likes this.
  3. johnerh
    johnerh Junior Member
    45
    Los Angeles
    I rotated them myself and put the higher tread in the back
  4. PriusCamper
    13,411
    5,413
    I very much appreciate people who rotate their own tires! You're rare & awesome because of that and would do more to assist you than others because of that if you ever need help.
    But, like I said in earlier posts, best MPGs are up around 95% of tread. 100% tread is bad for MPG and below 95% gets worse as the miles (tire particulate sheds & poisons streams, aka: 6PPD) roll by.
    johnerh likes this.
  5. ASRDogman
    8,047
    4,078
    So you're trying to use up the tires with the less tread to get two new ones?
    Grit likes this.
  6. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Did you adjust the pressures as Prius placard has different pressure front and back?
    iPhone ?
  7. bisco
    52,785
    you can really only tell mpg's by the tank
    PriusCamper likes this.
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Nose dive driver!!!
  9. ASRDogman
    8,047
    4,078
    Only logical reason to put new tires on the rear.
    Best wheels on the front are best to steer the car.
    johnerh likes this.
  10. johnerh
    45
    Los Angeles
    When I got them new they put them on the rear because apparently that’s the way they’re supposed to go they told me. I insisted on putting them on front but decided to rotate after a few months to see how it would impact mpg
    ASRDogman likes this.
  11. bisco
    52,785
    there is a reason for putting new tires on the rear wheels of a fwd vehicle, i forget, but google knows
    johnerh likes this.
  12. ASRDogman
    8,047
    4,078
    Some clown at a desk decided that was the way to go. They are wrong.
    Grit and johnerh like this.
  13. johnerh
    45
    Los Angeles
    Glad I’m not crazy lol. I guess I’ll rotate them again and put the higher tread on the front again.
  14. ASRDogman
    8,047
    4,078
    If you rotate them back, and your mpg improves, bingo!
    If not, it's another issue. While the wheels are off, you could clean the slide pins for
    the brake calipers, front and rear. Fairly easy to do.
    #34 ASRDogman, Nov 13, 2022
  15. PriusCamper
    13,411
    5,413
    It's because brand new tires take more than 400 miles to wear in properly and on front wheel drive cars don't get good MPG in that first 400 miles.
    johnerh likes this.
  16. nicoj36
    nicoj36 Active Member
    518
    162
    and grease!
    ASRDogman and johnerh like this.
  17. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    The new tire on the rear is policy at places like America’s Tire/Discount Tire.
    The reasoning is they are less likely to have a sudden blowout. A front blowout is supposedly easier to control vs a rear blowout.
    I haven’t experienced a sudden blowout in a regular/non-run flat in the 30 years I’ve been driving so I can’t say from experience, but I do take care of tires/pressures. I try to every 2 weeks…
    iPhone ?
    Grit likes this.
  18. bisco
    52,785
  19. PriusCamper
    13,411
    5,413
