[PROJECT] Lithium battery for Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Xeico, Feb 18, 2024.
  1. Xeico
    Xeico Member
    56
    48
    Folsom
    It is still ALIVE!
    I'm currently building the second prototype. The first one looks a bit scary, but it works great.
    Here's an example of a trip from Sacramento to Fairfield and back. The speed limit was under 65, and I was driving on cruise control.
    The car is a 2005, 225,000 miles on it, which is pretty good.
    James Analytic and Kromis like this.
  2. niko7
    niko7 New Member
    Tampa
    How did your battery project end up?
  3. Xeico
    Xeico Member
    56
    48
    Folsom
    Several cars are running in test mode. Unfortunately, I’m a bit busy and don’t have time to put everything into mass production. The project works and has proven its effectiveness. Maybe I relaxed a bit once everything started working and I proved to myself that the idea was viable.
  4. James Analytic
    414
    63
    Michigan
    Which cells are you using? Are those from a gen 4 lithium non Prime? I have a bunch of gen 1 Pip-PHV-Plug In Prius cells and plan to start working on better understanding the BMS and reading, processing and outputting the data of a 14S Brick for starters and using with a portable power station OUPES Mega 1 for now. Then appears like you are doing where using the gen 2 HV pack parts other than the NiMH modules and frame harnesses. Thinking that will be easier to code, i.e. translating the 4 NMC cells to look like a gen 2/3/4 block. Then, would be awesome to get to the time to be able to custom make the HV battery sense computer, ideally ultimately for the gen 1 Pip to provide more options in the future and rescue those.
  5. Xeico
    Xeico Member
    56
    48
    Folsom
    1) Honda, Ford, BYD, SUNWODA.
    2) The Plug-in Prius cells are too large and won't fit.
    3) Right now, I'm 3D printing custom enclosures for the batteries.
    4) You need about 58 to 60 cells in series.
    Honestly, I’ve lost some of my enthusiasm for the project.
    Between the recent tariffs driving up PCB costs and general price hikes, it’s just gotten too expensive - it's looking like around $700 in total.
  6. James Analytic
    414
    63
    Michigan
    Did you create a Youtube, github or some sort of repo online anywhere with your design(s)? Please share if you did, albeit I still need to read through all the Linsight related files.
    The Linsight LiBCM LiBSU seems to be able to utilize 60S max from what I recall reading, though no one has modified from what I've read so far for over the 42S or 48S maybe Ford pack if I am remembering correctly. Guessing might save some time and at the least inspire if I go another direction as would be nice to add an EV mode functionality and seemed like one other CAN bus controls functionality like a EV mode acceleration from a complete stop always to improve MPG's. PriUPS functionality would be great as well, so mobile medic not only for Priuses. :)
    Reads like I assumed right, your design uses the factory Prius HV battery parts and only feeds the contactors for power and HV battery sense computer sense wire connection for block electrical data?
    Amazing what is on the market now a days, albeit with size constraints in regards to cells capable of some serious capacity. Like if say 201V and using the 314aH LiFePO4 cells, that's crazy huge like ~63KWh guessing if grade A cells. Nuts! I haven't found what the latest high capacity NMC or whatever Lithium Ion/Polymer battery is as of late and cost effective. Seems all my reading migrates me to LiFePO4, though I need to stay focused on the cells we now have and to put to good use.
    I just picked up my last order of parts, I think at least, that I need to start working on the 14S external pack first phase. I'm going to really badly try to document on Youtube at the least, though I am so far behind on editing and other needs that I've only been posting unedited videos lately to keep me reminded of chores.
    Hopefully I can motivate you, as I know the powers at be seem to keep us down and waste some perfectly good enough objects. Seems good if not great to me and better than fantastical tangents from reality foolishness. Vehicles, especially reliable ones, can get people to work, school, chores and even survive in as lodging.
    $700 definitely is a good buy in the right environment (avg climate temps come to mind), so hope I can inspire you to keep on keeping on as I plan somewhat similar in the next phase after I better understand my over priced ESP32 thoughts direction regarding phase 1 design with the Daly and JBD BMS's with hardwired and the wireless displays for metrics with potential CAN bus transmissions, though more likely I'll get into the CAN bus transmissions in phase 2.
    #26 James Analytic, Jun 28, 2026
  7. Xeico
    Xeico Member
    56
    48
    Folsom
    I haven't really documented or shared the project anywhere. Since it involves a high-voltage system, I don't want someone without the proper skills to get hurt trying to copy it.
    The number of cells in series is simply determined by the inverter input voltage requirement, which is about 168–252 V.
    Yes, you understood it correctly. My solution only replaces the battery cells and adds a controller that emulates the original NiMH battery while monitoring the Li-ion cells.
    Honestly, it's much easier to buy an EV than build one yourself. You'll almost certainly spend more time and money building your own.
    I wish you good luck. But looking back, I definitely wouldn’t have done this. I spent too much time and money on it. It’s easier to just buy a new car.
  8. James Analytic
    414
    63
    Michigan
    Understandable, HV can be risky and I have faith and hope at least most are paranoid enough to not take on the endeavor. I tend to geek out and get into technical projects from my former life I am trying to bring back from a brief hiatus and I guess that started as a sabbatical that led to head traumas and more. I'm retired, so being disabled helps keep the blood flowing.
    I have this glut of gen 1 Prius NMC cells and will most likely have PRIME cells too, so with 150 or so of the gen 1 so will move forward for now with phase one being the Oupes Mega 1 expansion pack(s). I also worked for one of the largest lowest margin highest volume OTC store brand label and others and have a sense of being low cost and cost effective. Will see if helps here. Bonus is having most the parts and some lifer education money lets say to be honest. I can't stop learning, even if is slower now a days.
    One last question, what all did you use to sense the pack? The more I read into, I may have a breakdown voltage situation using the individual BMS's like I was planning. Reads like there might be an issue with the voltage ratings in Open Circuit situation where still have an issue with the HV conducting through and blowing the open MOSFETS in the BMS. So need to read into more and might have to borrow from the Linsight or design and make a 54S BMS or at least a sense circuit to input into the MCU for outputting the "NiMH adjusted NMC cell block" values.
    Curious what approach to took and literally actually used to do so, even if higher level components related for reading the cells and processing to output the block adjusted readings. Thanks kindly and wish me logic as well, the cult ceremonial charms worry me more. o_O :)
