Project Lithium customer review
Discussion in 'Gen 2 Prius Main Forum' started by Wrecit, May 23, 2022.
  1. Wrecit
    Wrecit Active Member
    188
    119
    Pittsburgh
    2001 Prius
    I
    Here are screen shots at top of hill
  2. Wrecit
    188
    119
    Pittsburgh
    2001 Prius
    I
    Here are screen shots back at bottom of hill at end of test
  3. Wrecit
    188
    119
    Pittsburgh
    2001 Prius
    I
    My son has a 08 with a 7 month old refurb from hybrid doctor out of Virginia. If you want I can run the test in his car for something closer to apples to apples
  4. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    I may have missed it but has anyone posted a side by side comparison of the two Lithium contenders, Project Lithium and NPB, showing specifications of weight, cell source, introduction date, Amp Hours, expected cycles, cost, warranty, etc., with a comparison to the NiMH OEM?
  5. Wrecit
    188
    119
    Pittsburgh
    2001 Prius
    I
    NPB is not lithium
    Another likes this.
  6. Another
    1,819
    520
    Naples, Florida
    That's good to know, is there a side by side for NPB, ProjectLithium and OEM NiMH?
  7. Wrecit
    188
    119
    Pittsburgh
    2001 Prius
    I
    Here are the project lithium specs
    Prius pack capacity (14 blades): 1.456 kWh
    blade capacity: 7000+ mAh
    usable capacity: 5600+ mAh (80% compare to NiMH at 40%)
    blade nominal voltage: 16v
    blade voltage range: 14v ~ 18.25v
    Max discharge power (<= 30sec): 30C or 210 Amp
    Max discharge power (<= 3sec): 80C or 560 Amp
    storage temperature (1 month): -20C ~ +45C
    storage temperature (3 month): -10C ~ +45C
    Recommend storage temperature: +15C ~ +35C
    product weight: 1100g (compare to NiMH at 2070g)
    Above result were obtained in the following condition:
    Temperature: 15~35C
    Relative Humidity: 45~85% RH
    Atmospheric Pressure: 86~1066 KPa
    NPB does not post this information on their web site but I believe they are designed to match the current Ni battery's performance from factory batteries. If this is the case here are factory specs
    Specifications:
    • total energy = 1310Wh = 1.31kWh
    • usable energy ~520Wh
      • Usable SoC window 40% (40 to 80%)
    • peak discharge power 21.2 kW10s and 30.0 kW1s at 50%
    • continuous power [W]
    • nominal voltage [V] = 201.6V
    • capacity [Ah] = 6.5Ah
    • voltage range [V] = 180V to 270V in use
    • weight [kg] = 37.2kg (82lb)
      • module = 1.04kg
    • volume pack = 66.9 litres (based on dimensions)
      • module = 0.57 litres
    • pack dimensions [m] = 863.6 (34″) x 406.4 (16″) x 190.5 (7.5″) mm
      • module = 19.6mm x 106mm x 275mm
    • number of cells [#] = 168
      • 168s
      • 1p
    • charge time [minutes]
    • cell format = prismatic
    • modules
      • 6 cells in series in each module
      • 28 modules in each pack
      • each module contains a charge controller and a relay
    • cooling system = forced air cooling
      • cool air taken from cabin, the cabin air can have moisture and hence some bus bar corrosion is seen in service
      • temperature is measured using 3 thermistors, and the air intake temperature with a 4th thermistor
      • dimples on module case to create air pathways
    • cell make and model
      • Panasonic
    • pack cost
    Key Pack Metrics:
    • Gravimetric energy density, pack = 37.2Wh/kg
      • Module = 45Wh/kg
    • Volumetric energy density, pack = 19.6Wh/litre
      • Module = 82Wh/litre
    • Gravimetric power density, pack = 570W/kg10s
    • Volumetric power density, pack = 317W/litre10s
    • Estimated cost $650 to $700 => ~$500/kWh
      • This appears high, but remember that a small battery pack has a lot of overheads in the control system, case, cooling, HV connections etc. Plus this is a high C-rate hybrid pack and so the cells are designed to last a lot of cycles.
    • Cell to Pack mass ratio
      • module to pack mass ratio = 78.3%
    • Cell to Pack volume ratio
    Another likes this.
  8. Another
    1,819
    520
    Naples, Florida
    Just so I understand why this works so well without modification of of the BMS on the car, maybe someone can explain...
    The way the Prius BMS works is merely by monitoring by pack voltage? And it tries to maintain the voltage between 40% and 80% of the OEM NiMH spec voltages?
    And then the BMS charges the higher capacity Lithium Ion or FePO4 cells in the new pack without 'knowing' that it is imparting more energy into the high capacity pack? Then on the discharge side, it does not have to kick in so early.
    Does the Lithium battery pack charge more slowly than it could because the current is limited to what the BMS thinks a NiMH can take?
    What limits this charging rate on the Prius?
  9. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,017
    NJ-USA
    The hybrid system tried to maintain 40-80% State Of Charge. There's a chart from Toyota somewhere that shows the approximate pack voltage to SOC. So the ecu seems to care about voltage level for determining charge - discharge SOC "limits" for the pack.
    I would imagine that it uses the current sensor to not exceed the power limits of the inverter (or the battery fuse). I'm sure ChapmanF will chime in at some point with details.
    So the Li-ion pack has more useable capacity (?) within the same voltage (SOC) range vs the NiMh. I would think that there is also some gain due to lower IR (less waste heat) for the same power. And "gain" due to lower overall weight.
  10. Another
    1,819
    520
    Naples, Florida
    This is an interesting topic.
    Despite many posts in this forum about how crazy it is to try to keep a fifteen plus year old car on the road, mine really looks and drives nearly like new. The original battery is about 60% of original capacity which would be nice to increase but spending $2k to do that is not happening.
    I’ve read the background on the project lithium website about their noble quest to search for the optimal cells over the years and their knowledge of the Prius is not disputed. But for what one is buying, that is, cells and some plastic housing along with the resistor balancing network it’s seems the price is crazy.
    Hopefully more competition will enter the market and drive prices lower just like the OEM NiMH and the New Prius Battery folks seem to be being displaced by PL. I don’t see a great barrier to entry for anyone that wants to enter the market. The Chinese will sell their mother into slavery to the highest bidder. Knock offs are the rule there.
    There certainly seems to be a market for replacement batteries given people lining up for the meager supply, so competition should come.
  11. Moving Right Along
    Moving Right Along Senior Member
    739
    596
    @Another I tend to think the competition is already here. New Prius Batteries and Project Lithium are the competition that gives very good new options to the original battery pack. I do not expect many other companies to get in that business due to the nature of car ownership. The vast majority of Prius owners (over 95%, according to statistics) will sell, trade in or trash the car before it gets to 200,000 miles. And the original battery pack rarely has any problems in the first 10 years of operation. So it is a comparatively small market of people who are having battery problems and prefer to replace the battery over replacing the car.
  12. Another
    1,819
    520
    Naples, Florida
    Famous last words.
    There will be competition if someone is making money. Given the apparent supply shortage of PL where people seem to agonize over getting that very last space on a waiting list for a battery, it seems there is an unfulfilled market.
    Like most things, regrettably, probably will be a Chinese knock off since the USA offshores it’s environmental problems by hiding them in China and in turn penalizes USA manufacturing. And the Chinese have no IP protection for foreigners. The Hybrid guy’s disassembly video gives people 90% of what they need to know to produce one. Getting a used PL blade to reverse engineer the cell balancer is all that is needed.
    There is a huge market for replacement Prius batteries. The lithium cells offer many advantages in terms of capacity and storage abilities over NiMH. The PL design seems simple enough. The cost is too high and the price differential, between OEM and a startup who’s ability to honor a warranty, is too small.
    Competition is always good.
    Prius Rising likes this.
  13. alftoy
    alftoy Senior Member
    1,132
    520
    Saskatchewan, Canada
    Order here
    Get Toyota Prius Hybrid Battery Replacement | EnnoCar
    #33 alftoy, Jul 22, 2022
  14. Wrecit
    188
    119
    Pittsburgh
    2001 Prius
    I
    Ummm.......both NPB and project Lithium are the brain child of people that live in America BUT are both manufactured in china. Are the American "inventors" making a few bucks? Sure. Are they making a fortune? Hell no. Go fly over to China and talk to some of these factories about what it costs to buy the materials to fabricate these batteries. Yea labor rate in china is well below the American worker but material costs are pretty much equal and demand for battery material is only going up so material costs will rise.
    If there is not a "china knock off" already there's a good chance there never will be on these because china already is making them.
    rayluo likes this.
  15. alftoy
    1,132
    520
    How many of your personal electronics and appliances are made in USA? Penalize USA manufacturing? You are part of the problem. Stop buying Made in China. Another hypocrite.
    Especially your comment "Competition is always good" after complaining about the state of USA manufacturing. Or is it your juvenile emotion that PL is making exorbitant profits, not unlike that vaunted USA company Hewlett Packard and their ink cartridges made in USA, maybe. Ink cartridges that per ounce is more expensive than a barrel of oil.
    #35 alftoy, Jul 22, 2022
  16. Wrecit
    188
    119
    Pittsburgh
    2001 Prius
    I
    Thanks Alfroy. Interesting link. It seems from looking around their site that toasters NPB is actually the "Chinese knock off" of a Chinese product since they have been marketing his cylinder design for over 5 years lol
  17. alftoy
    1,132
    520
    Interesting that we haven't heard from Toaster regarding the problem with this members NPB.
    Help please part dos: HV Battery Problems | PriusChat
    There is a PC member that did buy the Nimh battery from Ennocar, and had numerous problems. Cost more to ship it back if he could. Good luck.
    #37 alftoy, Jul 22, 2022
  18. Another
    1,819
    520
    Naples, Florida
    I'm not sure if you have, but I have been to China and know very well the business practices and climate there. The China problem is caused by the decades of offshoring of USA manufacturing. The offshoring is enabled by ignorant and greedy USA politicians who provide incentives to hide the real costs of manufacturing, both labor and environmental.
    The displacement cost of USA jobs is borne by the taxpayers and consumers. The USA cannot even make its or enough of its own semiconductors, solar panels, ibuprofen, antibiotics or more relevantly here, battery cells. Any and all of these components could be made here. Even the Lithium, and other materials can be sourced here but are not due to the fact that it is easier to avoid the costs of environmental stewardship by hiding it in China where the environmental problems abound.
    I have no insight into the profit margins of PL or NPB as you seem to. It could be that they are not making much money, which is even more sad given the simplicity of the devices.
  19. Wrecit
    188
    119
    Pittsburgh
    2001 Prius
    I
    I am lucky in that you can not outsource my line of work to China (though I do work with components and materials made over seas from time to time) yes America has a very serious NIMBY issue and most are to short sighted to realize that just because they do not see the pollution created by the products they use and love does not mean that the creation of those products is still not dirty as hell.
    A decade ago I was part of a group that imported a product from China that revolutionized an American sport (for the worse IMO) I have also looked into battery production for something unrelated to prii and got a loose understanding of the material and production costs and the prices that PL and NPB are offering do seem in line from my past knowledge.
    I don't know what widget you are personally producing in china so can not give a direct answer but I do know that comparing non electrical item production to electrical or heavy machining production in china are 2 different worlds. Raw materials dictate the price when china is involved. Plastic tends to be a very static price. Steel, lithium, microchips, ect can be very erratic, especially in the current world supply market.
  20. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,980
    Texas Hill Country
    Some people are way off base here. The moderator needs to step in.
    alftoy likes this.
