Project Lithium customer review
Discussion in 'Gen 2 Prius Main Forum' started by Wrecit, May 23, 2022.
  1. Wrecit
    Wrecit Active Member
    188
    119
    Pittsburgh
    2001 Prius
    I
    Yea sort of derailed my own thread lol. Noticed over the past few years nothing will spark a fire quicker than OEM vs after market and new school vs old school tech.
    alftoy likes this.
  2. Hybrid_Warrior
    Hybrid_Warrior New Member
    And its conductive metal - I took an ohm meter to the pack. My guess is the nipples and ribs create a space between adjacent cells which allows convective airflow which is augmented by the forced air blower. The Panasonic Prismatic Pack is 94V0 - it says so on their datasheet. Of course NiMH packs do outgas a bit during operation which is what the rubber tubbing that goes to the nipples on the top is all about. That tube goes off to the exhaust vent. You can read about the chemistry venting at the battery university website, great resource.
  3. Hybrid_Warrior
    I really have no prejudice against any innovation that comes along or from where. The question is legit as it raises a safety concern. There is no such thing as a chemical battery charge/discharge process that is not exothermic. That temperature delta will vary with the chemistry and is mitigated with design augmentation to evacuate the heat when it occurs. As noted Tesla has to do this with their three battery chemistries. In fact if you look at the new 4680 battery the design is heavily modified to move heat out of the cell as fast as possible. This will allow faster charge times. The pack, again, has a liquid cooling loop and the radiator fans operate during charge to move that heat away. So lithium does not have a pass on thermal management - not by a long shot.
    The second aspect about the upgrade is there is no firmware change to the BMS module (battery management system) as far as I can tell. The BMS is fine tuned to monitor the temperature/charge[discharge] current curves to mitigate danger. This is why your Prius "runs" when the battery pack gets to full green on the display. Its adding a "dummy" load to the system. If you look at off the shelf BMS' they have specific tables to use with specific battery chemistry. So that is curious.
  4. Hybrid_Warrior
    Thanks. I've used DrPrius - which is fine for battery SOC monitoring. I use Torque Plus - with the Prius PIDs downloaded - to be able to chart some interesting things. For example you can monitor your Catalytic degradation which is useful. When I line graph the temps of the inverter and the battery temp sensors (3) I can see a direct relation between the peaking of the temps. You have to go into a non-motor charging state to really see the worst case. For example if you take your foot off the gas and roll (in B) down a very steep long hill you will watch the charge cycle and the heat rise dramatically. Going up the same hill, obviously with gas, at a very slow speed (not normal driving unless you are in a traffic jam) with do the same. This prolonged sustained "stress" will peak the temperatures. And that is the fundamental question. How badly? Because regardless of how badly the system must work and it must protect itself with on demand cooling. For eample in Dr Prius you can force the fans to turn on at a lower temp. That's fine - but not stock obviously.
    And FYI for those who have not heard. Here in California Prius' are prized for their mileage and longevity with low cost of maintenance. Taxi companies use them alot. I asked a cabbie, when I was taking a run to the airport, what sort of mileage they are seeing. He said 500,000 miles is doable with a single battery swap and the engine, being a true timing chain is bullet proof. Most original batteries lose the peak economy (46 to 52 MPG) by 320,000. Note that cabbies run all day with lots of charge discharge cycles keeping that battery young. I asked one of the battery swap companies what they are seeing and the answer was that the center NIMH cells tend to go out first because of heat stress. And the guy noted that deep cycling can bring a battery back to life for a couple more years. Note Toyota runs the batteries extremely conservatively between 20 and 80% charge to specifically reduce peak heat events.
  5. Wrecit
    188
    119
    Pittsburgh
    2001 Prius
    I
    I can't really graph the temp but on the hill test it only climbed 1 degree on the down hill according to the Dr Prius app (I took the screen shots as soon as I hit flat at top and bottom of the hill)
    All 3 rebuilds I have driven (all done by hybrid doctor out of VA) "new" ran in the 100 to 115 range with resistance at 20. There is obviously heat in the lithium reaction battery's running high 90's when outside temp was 85 but I have only seen temps crest above 100 2 times so far and outside temps were north of 95 to get that (windows down no AC running because wife is a reptile and hates temps us mammals call comfortable lol)
    When I am driving with cabin temp set at 72 I have not seen battery temps any higher than low 90's with normal being 85 to 88.
    I have full confidence in the Toyota design and how the gas is vented but will admit to liking the fact that lifpo4 does not require venting of toxic gases.
  6. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    Not sure what you’re talking about. I don’t make anything in China, never have. Never will. I’ve just dealt with them long enough to know how they work.
    We need to bring manufacturing back to the USA.
  7. monoshock
    monoshock Member
    66
    27
    Rocky Top TN
    I finished my NexCel install yesterday, I've only driven about 100 miles so far. I can tell the ICE does not kick in as much, and when at a stop the A/C runs on the battery much more. I'm going to get a kit for my other Prius when the stock battery goes out.
    I'm very happy with the purchase. $2379.
    ColoradoCrow and nancytheprius like this.
  8. Another
    1,819
    520
    Naples, Florida
    How bad was your old battery? Did you need to replace it or just replaced it for other reasons? What was the trigger?
    TheLastMojojomo likes this.
  9. Another
    1,819
    520
    Naples, Florida
    Does anyone have any first hand information on how long a Prius with the installed Project Lithium battery can sit unused so long as the 12v battery is charged? Seems like everyone that installs one uses the car daily. Does PL offer any guidance?
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    I know for fact a brand new Toyota NiMH battery can sit on the shelf for 2 years and still be installed in a car and it will fire right up.
    I'd like to think a new Lithium could do the same or better.
    alftoy likes this.
  11. Wrecit
    188
    119
    Pittsburgh
    2001 Prius
    I
    Would say justifying project lithium if you are a "country average" driver would be more difficult IMO. We are well above the norm (I am expecting somewhere in the 30,000 range for this year.
    As such the longest we have gone without using was 4 days one time so I have no idea about how long it can sit. When my numbers pop up tonight however I will take a reading and let it sit for 30 days to give an idea
    Come on mega numbers lol
  12. pasadena_commut
    pasadena_commut Senior Member
    3,069
    956
    Southern California
    The self discharge rate of the cells in a brand new battery should be very closely matched. So even though it might self discharge down to quite a low voltage in that time, it would still be balanced. That sort of symmetry will generally not be present in a battery with a lot of miles/age. If such a battery sits for several weeks some cells may have voltages substantially less than others, which can potentially result in damage to those cells when the car starts up. This is I think the reason why most hybrids have a warning in the users' manual stating that these cars should not sit unused for more than a couple of weeks.
    As a matter of personal observation, in the two battery failures I had with an IMA pack on our old Honda Civic Hybrid both followed shortly after being parked for an extended period. The first one was when it was parked at the airport during a trip, and the other was when it was having transmission work. (The HCH I CVT transmission was a fragile POS.)
  13. oreomonster
    oreomonster New Member
    Washington State
    Why does your car show 0.0mpg? Does the lithium battery prevent accurate readings? Or did you just clear?
  14. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    He is stationary, presumably, so he can safely take the photos. Notice that there are no energy lines on the Energy Monitor screen.
  15. LEARNER
    LEARNER Junior Member
    86
    Hey how's the project lithium battery doing now? Researching it for when my $800 rebuild goes bad but so far so good according to Dr Prius (from Hybrid Geek).
    Owner of 2004 Prius bought new looking forward to making the 29 year mark and then some :).
    Prius Rising likes this.
