Project Lithium installed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lumpy05, Dec 21, 2022.
  1. Lumpy05
    Lumpy05 Junior Member
    Installed Nexgen lithium cells in my 2008 Prius with nearly 230k miles. Took roughly 4 hrs, straightforward installation with no issues. I am extremely pleased! The car just drives better, I did not have a failed pack but clearly worn cells that would discharge overnight. Engine was working hard prior to pack refresh. Now everything is smooth and just better. Just over 200 miles thus far but believe I will see the 10% fuel economy improvement, seeing 48 mpg on the trip computer where I was seeing 44 prior under similar driving scenarios. Happy to answer questions. Also not sure what to do with removed cells, looking for advice/ options on that.
    MarkySparky and PriusCamper like this.
  2. JC91006
    16,932
    8,640
    Sell them or keep them for backup use. Just in case the Lithium doesn't work out
  3. PriusV17
    PriusV17 Active Member
    435
    206
    CA
    2017 Prius v wagon
    Cool. If you live in cold weather let us know how it does. Don't sell it, you'll just pass the buck. See if the dealer will give you cash back for the pack. Or just give it to them free to recycle. Let us know how much they give you cash back if they do.
  4. Lumpy05
    I’m located in Indiana single digit temps starting tomorrow will see how battery does in the cold for sure.
  5. JC91006
    16,932
    8,640
    Not sure you can really compare properly with a degraded 14 year old OEM battery vs a brand new battery. Your results for the new battery should be superior. But I would still keep the old battery just in case some reason the Lithium battery doesn't work well in your climate
  6. Rmay635703
    Rmay635703 Senior Member
    2,686
    1,725
    Somewhere in Wisconsin
    2013 Chevy Volt
    -38F around here soon
    Would be a good test area
  7. nancytheprius
    nancytheprius Active Member
    365
    157
    iowa
    my 16 year old pack failed last month. i replaced with a brand new OEM battery, and i noticed almost no changes (besides no more lights on dash or codes) So i think it’s possible to compare them!
  8. JC91006
    16,932
    8,640
    Well if you let your car sit idle on battery power, I'll bet the new battery will drain much slower than your degraded pack. Also if you were to climb a hill, the new battery will provide a lot more assistance before draining. You really can't compare them once under load, the degraded one will not perform well.
    nancytheprius likes this.
  9. PriusCamper
    PriusCamper Senior Member
    13,396
    5,410
    Pacific Northwest, USA
    Myself & a dude in Denver are working on a pack heater to keep things going in Sub-Zero temps for Nexcell... The car already has a way to protect itself from using OEM battery in super cold temps. Discharging is not as problematic as charging... Hit me up so we can get you in our testing...
  10. alftoy
    alftoy Senior Member
    1,132
    518
    Saskatchewan, Canada
    Pack heater as in interior car warmer? They still make those? Purpose is to heat interior over night in -30 temps to keep lithium pack from freezing?
  11. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    A $25 space heater will keep the inside of a car pretty toasty.....
  12. PriusV17
    435
    206
    CA
    2017 Prius v wagon
    If anyone has a FLIR thermal camera. We can see how the Prius exhaust system heats up the car from the bottom in frigid temps. Heat from exhaust can reach 400 to 500F. There may not be any need to keep the battery warm.
  13. alftoy
    1,132
    518
    True enough. Even cheaper a ceramic 250 watt bulb with clamp fixture for coop, $17.
    Just curious what PriusCamper was developing for a pack heater.
    "Myself & a dude in Denver are working on a pack heater to keep things going in Sub-Zero temps for Nexcell."
  14. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    410
    2013 Prius Plug-in
    so... two years later... how are the batteries holding up?
