Project "pissed off prius" underway
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Acidbass32, Feb 11, 2016.
  1. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    I have a rally coming up in a few weeks, I will be sure to have plenty of pictures taken. Right now I have pictures of the aftermath of the rally a few months ago, but my images aren't uploading for some reason.
  2. orangeeeyore
    orangeeeyore Junior Member
    51
    cool, are you rallying around Galveston?
  3. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Yeah there is an annual beach rally which is always fun. Also some amateur WRC stuff in the central Texas area too.
  4. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Here are the horn install pictures and the pictures of "pissed off Prius" after the most recent rally. IMG_6367.JPG IMG_6456.JPG IMG_6457.JPG IMG_6458.JPG IMG_6479.JPG IMG_6480.JPG
    Data Daedalus likes this.
  5. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    I just ordered a
    PTR11-02060 SUSPENSION, TRD, REAR SWAY BAR
    For the pissed off Prius. I am still looking for a front sway bar. There isn't a junk yard close by that is open when I am not in school, so online is my only option. Anyone know part numbers for the bushings and the front sway? I am looking at this right now Dorman® - Toyota Matrix 2008 Front Sway Bar, But if anyone has any input it is greatly appreciated.
  6. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    I see a bunch of used corolla front bars on ebay. apparently, they are the same all the way from '03 to '13. about $50. that's where I got mine, and several other folks did the same.
    I bet that dorman bar is made in Taiwan or china. I'd rather have an oem bar.
  7. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Fair enough, any particular preference on the bushings/ being that there are only 2 I'm leaning towards the OEM ones like you did instead of the poly.
  8. a_gray_prius
    2,927
    783
    IL
    Bought a Dorman part to replace an assembly on an aging Honda. It was like 3/4 inch too long and even when applying force to the rubber bushings, it wouldn't fit. Bought an OEM for a crap load of money in comparison and it dropped right in, no force needed.
  9. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
  10. 69shovlhed
    2,170
    752
    Delaware
    I got my bushings with the bar. I believe the brackets are the same, so if you don't get the bushings with the bar, just order oe front corolla bushings and use your brackets
  11. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Yeah ended up just snagging the OEM bushings as well from the corolla. I should have them in by Thursday, which means they will go on Friday.
  12. orangeeeyore
    51
    a legit rally prius dreams do come true
  13. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    No joke right? I get weird glances from other guys on campus in their built jeeps and trucks when my car is covered in mud after a little off road excursion. I have future plans to add a CB radio with a PA system to keep in touch with my support vehicle and a custom exhaust.
  14. Brent H
    Brent H New Member
    Denton
    SUPERBADASS
    Acidbass32 likes this.
  15. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    WOOOOO!!! Sway bars came in today! Putting the rear on between classes tomorrow, the front one I need to paint red before I install it on Tuesday.
  16. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    The rear sway bar is in and boy do I already feel a difference. After spending 15 minutes under the car in a college dorm parking lot, I managed to get it in no problem ( I do apparently have a problem taking a picture though). Front sway bar is getting painted on Sunday and installed on Monday. upload_2016-2-27_6-18-6.png
  17. 69shovlhed
    2,170
    752
    Delaware
    wrap the front bar with painters tape or something so you don't chip the fresh paint on the install. its a tight fit getting it past the subframe.
  18. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Will do, its the same torque rating and bolt size right?
  19. 69shovlhed
    2,170
    752
    Delaware
    yeah. the only thing different is the rubber frame bushing I.D.
    torque specs and hardware all the same.
  20. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    So I am installing my front sway now and the subframe bolts wont line up on the control arm. Any suggestions to get it all good to go? I have been working on it for about 4 hours now and am starting to freak out lol
