Project "pissed off prius" underway
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Acidbass32, Feb 11, 2016.
  1. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    I would suggest the rear and front sway bars before anything else because thats going to be the best upgrade for the money. The strut tower brace makes a noticeable difference as well in my experience. The order of the braces for my car is the chassis brace, the underbrace, strut tower brace, rear sway and front sway and I recently installed a set of performance coilovers. The front sway is where I would start if I had to do it again, and be sure to change the bushings for the front sway as well. I know Justdidit has poly bushings which are stiffer and overall better. However, I just used the OEM 2008 corolla rubber bushings because I live on a beach and the sand would mess up the poly bushings.
    Mavi and Justdidit like this.
  2. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Any suggestions on how to install my roof rack lighting on the cargo bin? I have the switches and such, but I don't want to drill holes in the roof.
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Run the wires back through the liftgate area?
  4. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    That was what I was thinking, but routing the wires to the dash for the rocker switches would mean it would have to go through the headliner.
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    I ran wires thru my headliner on my 2008 when i patched my puddle lights up to my dome light. Pretty simple to do.
    For my 2007, when I do it again or anything similar, I'd drop the wires immediately and run it down in the door channel along side the driver side doors.
    #85 Justdidit, May 16, 2016
  6. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    I am hoping to work on it tomorrow when contractors get their crap out of my garage. To map out how to run everything from the top of the car to inside to the dash to the jump point in the engine bay.
  7. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Quick question, does anyone know or has anyone had any issues with the control arm bushings after they have lowered their gen 2? I have noticed recently that whenever I have a sudden start or brake, there is a pretty loud knock. The car has 183,000 miles on it and they are the stock bushings, but im not sure if it is the sway bar links or the control arm bushings.
  8. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    I may have figured out the problem, I think it's my CV joint actually, because when I am parked and turn the wheel to the limit to the left and right I hear a loud clicking sound. Oh the joys of having close to 200,000 miles on the car.
    Justdidit likes this.
  9. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Replacing the CV axles was a piece of cake, nothing too spectacular there. However, it helps ten fold to have a lift at your disposal, because you need to top the transmission fluid off after you put the new axles on. This can only be done from under the car, thanks a lot Toyota. I still hear a creaking sound when I am turning at low speeds, so I took it to the local dealer and one of the techs and I looked under the car, checking all the bushings, motor mount, subframe, control arms, etc. and no dice to see what was causing the noise. So I guess I have to deal with it and ease up on the baby outside of rallying.
  10. Fred_H
    Fred_H Misoversimplifier
    562
    488
    28
    Germany
    Have you also looked and listened from above?
    Are the strut bearings free and well greased?
    Are the upper strut mount and rod nuts properly torqued?
  11. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    I'm going to go over everything again since I did switch the stock struts to coilovers with pillowball mounts a few months ago, I hope it isn't the transmission.
  12. orangeeeyore
    orangeeeyore Junior Member
    51
    I know I'm out of order, but where you'd get the wrap from?
  13. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    I got the vinyl wrap for the interior from amazon. There are a few places that sell it online, I just searched for "stickerbomb wrap" and it was 6 bucks for 5'x3' which is plenty to cover all the plastic in the car. Theres other types you can get also, I considered a desert camo and a carbon fiber as well since I have the forest camo in my raptor.
  14. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Update: still no Idea where the clicking is coming from. I just replaced the CV joints and figured I could rule those out, got new coilovers less than 10,000 miles ago and after a good rain, the clicking has gotten worse. The clicking seems to happen when I am taking off from a red light, braking suddenly most often. I have noticed the clicking sound is a single pop or click, and it seems to be coming from the drivers side towards the wheel. I checked the strut mounts and they are fine, the coilovers are fine, the brakes are brand new as well as the CV joints, it hasn't affected my drivability but it is really aggravating bec
  15. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Figured this out yet? Any chance you could have someone else drive the car while you video the car and capture the noise??
  16. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    I have had to deal with summer courses (cal 2 and organic chem) for the past few weeks, but I was going to mount my goPro underneath to see what the deal is.
  17. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    FINALLY! Finally I got the roof lights on, and they are "bright as day" according to my friends. they don't look bad either. Getting under the car tomorrow to sleuth around looking for the noise. Thinking its the rack and pinion.
  18. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    So electrical gremlins are afoot. A few times over the past month or so (before I installed the roof lights), whenever I go to press the power button on the car to turn it off, it'll just go completely dark (like unplugging a computer straight from the wall). After about 10-30 seconds, the car will turn spontaneously back on (like pressing the power button without the brake depressed) and sometimes it will happen even when the key is taken out of the slot. Anyway, when this does happen the clock resets and the AVG MPG resets back to zero, and my fuel gauge resets as well. Any suggestions? This started happening when I switched from my main keyfob to my back-up.
  19. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Alright folks maybe you guys can confirm my belief here. I think one of my rear Ksport coilovers is blown out. However, there is no change in driving, handling or the like. Just this god awful noise coming from the rear passenger side. The noise happens when going over bumps typically and when I rock that side of the car you can hear the clicking as well. Here are two links to youtube videos with whats happening. Inside the car while driving
    and outside the car rocking
  20. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    if it was me, I'd drive the rr tire up on a curb, and lay under the back of the car with a strong flashlight while a heavy friend rocks the car for me. sounds like something is loose enough you should be able to see where the noise is coming from.
