Projector Fog lights (BOLT ON) finally!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by cheizy, Apr 19, 2015.
  1. Bonzie
    Bonzie New Member
    Torrance, Ca
    Thanks so much!
  2. Bonzie
    Bonzie New Member
    Torrance, Ca
  3. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Did you get a set?
  4. Bonzie
    Bonzie New Member
    Torrance, Ca
    Since I'm new it's not allowing to reply. I'm not sure what to do now. He sent me the price but I can't send his email for PayPal.
  5. Bonzie
    Bonzie New Member
    Torrance, Ca
    Whoa, sorry still getting used to the site. xliderider please PM me your email for payment.
  6. xliderider
    8,140
    3,276
    Honolulu, HI
    I'm not the one selling them lol.
    Accordlayingkit and cheizy like this.
  7. cheizy
    cheizy Member
    94
    129
    Los Angeles
    Bonzie, check your messages it's the one that looks like an envelope on the top right hand corner.
    Thanks!
  8. Bonzie
    Bonzie New Member
    Torrance, Ca
    Sorry xliderider... again I'm new:cautious:
  9. Nobody123
    Nobody123 Member
    160
    33
    United States
    2015 Prius Plug-in
    I entered the idea of light bars, but you have to cover them up when you get to the highway. Here's a short clip of the high beam.
  10. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    I got these bad boys installed. The lens is really thick vs other after market lens. I loved them. Worth every penny. Check them out. Make sure you point the circle down not up. The projector is very far out. I used LED bulb 3000K. Don't need a ballast to power them. Instant on vs HID.
  11. cheizy
    cheizy Member
    94
    129
    Los Angeles
  12. Nobody123
    Nobody123 Member
    160
    33
    United States
    2015 Prius Plug-in
    I'm using just a standard Sylvania H11 bulb in these projectors and they fit great as expected. When I ordered the pigtails, I bought these off ebay: 2 Piece H11 H8 H9 Wiring Harness Socket Wire Connector Plug Power Cable Cord | eBay
    I didn't pay close attention to the picture because I thought it was just a stock picture and they would send me the correct connector, but instead this came:
    The black connector on top is the OEM Prius connector for the H11 low beam. The lower one with the yellow gasket is what came from ebay.
    Looking over the auction listing again, I think you're supposed to use this connector to plug into an existing H11 male connector, and then the side with the yellow gasket plugs into what looks like a 9006 bulb.
    Did I mess up?
  13. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    If I have the H11 connector, why do u need the harness? Did I miss something?
    VS980 4G ?
  14. xliderider
    8,140
    3,276
    Honolulu, HI
    I plugged the H11 bulbs in my projectors directly to the factory wiring harness. The one you have pictured isn't an H11 connector, contact the eBay seller and send them that picture. They sent you the wrong one. Get a refund, you don't need them.
  15. xliderider
    8,140
    3,276
    Honolulu, HI
    The spacing between the connectors in the ones you received are too far apart, H11 connectors should look like these:
    H11 H8 Wiring Harness Socket Wire Connector Plug | eBay
  16. xliderider
    8,140
    3,276
    Honolulu, HI
    I'm guessing he is trying to wire up the projector foglights without using a standard foglight wiring harness, the H11 connector pictured is of the lowbeam H11 connector on the headlight.
  17. Nobody123
    Nobody123 Member
    160
    33
    United States
    2015 Prius Plug-in
    Yep. I want to make my own harness. The black connector in the pix is the low beam.
  18. nedear88
    nedear88 My 1st Prius.
    246
    142
    San Bruno, California
    I got the same projector fog from Cheizy, I had installed HID kit and able to plug in the H11 connector in the HID ballast WHICH is 9006 type, I just adjust/bend the pins in the ballast, it fit right it.
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    apt5020 likes this.
  20. ian2002525
    ian2002525 Junior Member
    22
    Nashville, TN
    OP, I love your headlight color. What did you done to the headlight? Just simply changing the low beam bulbs?
    Are they 5000k or 6000k bulb?
    Thanks!
