Projector Retrofit Insight Needed
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Absalom, Jan 9, 2019.
  1. Absalom
    Absalom Junior Member
    42
    42
    Denver
    Hi all, needing some info on which projector will best fit the stock halogen projector housings.
    3" DDM D2S?
    2.5 DDM H1?
    Retroquik?
    Thanks in advance!
  2. Danger
    Danger Member
    175
    22
    Frisco
    If you get the RX350 projectors they drop right in. Make sure to get the Non AFS. If it has AFS some slight cutting will be needed for it to fit. But it will bolt on. If I were you I'd go with the G5 3" projector. The retroquik adapters do make things easier. But you can make yourself some if you compare the OEM and aftermarket projector.
  3. ilovegirls
    ilovegirls Member
    172
    40
    San Diego
    I used the rx350 non afs on my last retrofit on my lexus ct200h. These where by far the easiest to do. Easy in with slight modifications to the shroud.
