Prolong™ Intelligent Discharger thermal testing
Discussion in 'Gen 2 Prius Technical Discussion' started by jeff652, Aug 4, 2015.
  1. jeff652
    jeff652 Senior Member
    606
    623
    Idaho
    Here is a photo of our Prolong™ Intelligent Discharger undergoing some final thermal testing. The good news is that it can pull over 2.4A at 287V in 105F intake temperatures without breaking a sweat. The bad news is that we are setting the thermal safeties such that you will never be able to do this ;)
    For those that do not know, our Prolong™ Intelligent Discharger allows easy battery discharge to better facilitate the reconditioning process. It will auto-taper battery load from an efficient 2.5A down to a battery protecting 200mA. The discharge termination voltage is easily set by the user, then the go button is pressed. That's it! The Discharger does the rest, turning itself off when the job is done.
    Here is a sample graph of the discharge load auto tapering on a 2009 Camry Hybrid:
    We are taking invitation based pre-release orders now. If you received an email, please respond timely before we move down the list. If you want to be on the list, please PM or email me. :)
    gdanner likes this.
