Prolong Battery Charger Plug
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by JMJCATH, Aug 31, 2020.
  1. JMJCATH
    JMJCATH Member
    91
    52
    Here
    Does anyone know where I can find a plug for the Prolong Battery Charger? Mine no longer works.
    I contacted Hybrid Automotive and they said to buy the extension for $79 and cut the plug off of there. :eek:
  2. Tim Jones
    Tim Jones Senior Member
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    Have you looked on Amazon... I had one of the units and it seemed like a plug you could purchase online.... then splice using a continuity tester.
    jerrymildred likes this.
  3. JMJCATH
    JMJCATH Member
    91
    52
    Here
    No. I wouldn't know what plug to look for.
  4. Tim Jones
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    does it have pins and how many or is it female?
    Picture of plug end?
    Google din plugs
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    If you're just replacing the connectors on the ends, you just get a pair that match each other and have the right number of terminals (four, iirc). Then replace the old connectors with the new ones making absolutely sure you connect the two cables exactly like before. Other than the number of wires, they don't need to match the old connectors, just each other. Hence the need for the tester that @Tim Jones mentioned.
  6. JMJCATH
    JMJCATH Member
    91
    52
    Here
    Here are some pictures of the plug.
  7. jerrymildred
    11,517
    14,158
    Tampa, FL
    Something like this might work if it fits the case. You'll need to replace both parts. I'm not home, so I can't look at mine (which is VERY old). All you really need is a 4-pin connector that fits.
    Perhaps this?
    And, from now on, don't connect or disconnect that connector when the charger is plugged in. I did that one time, saw the spark, and said, "Not doing that anymore!" Breaking a DC connection under load makes a lot of arc which burns up the contacts. I got the same kind of arc screwing in and unscrewing the lightbulbs in the manual discharger. But light sockets and bulbs are easier to replace.
  8. JMJCATH
    JMJCATH Member
    91
    52
    Here
    jerrymildred, I don't see a picture in your post.
    I always connect the charger to the traction battery first and then plug in the charger to A/C. I'm guessing the open is within the plug itself since I can get it to work if I wiggle the cord near the plug and hold it in place.
  9. jerrymildred
    11,517
    14,158
    Tampa, FL
    Must be your ad blocker. It's there. Every once in a while someone can't see the links. I don't think it's ever been anything but an ad blocker.
    (y)(y) Sounds perfect. I wonder how it got so scorched looking. o_O
  10. JMJCATH
    JMJCATH Member
    91
    52
    Here
    Hybrid Automotive said that connector wouldn't work since the connector requires a special key. I'm guessing I'm out of luck unless I buy the expensive extension cable.:(
    Thank you for your help!
  11. jerrymildred
    11,517
    14,158
    Tampa, FL
    I assumed you would replace both ends. I certainly would.
  12. JMJCATH
    JMJCATH Member
    91
    52
    Here
    Yes, I plan on it if I can source it!
