Prolong Battery conditioning kit
Discussion in 'Gen 2 Prius Accessories & Modifications' started by 44Zoomer, Jul 29, 2017.
  1. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    In case you haven't read the instructions (bold font theirs): "A completely empty pack takes just under 24 hours to reach a full state of charge and balance, depending on cell efficiency. At no time should the combined 'filling' and 'balancing' times exceed 48 hours."
    WilDavis and Raytheeagle like this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    I would stop and if you were only going a top end balance, call it good. If doing a discharge cycle to 134 volts, I would start that.
    Don't forget to let the car sit after the last charge cycle for at least an hour (y).
  3. 44Zoomer
    44Zoomer Junior Member
    35
    Hawaii
    I knew about the 48 hours and I stop it at 43 hours. Bet I have some bad cells. Anyone wanna guess how many? i say two?
  4. 44Zoomer
    35
    Hawaii
    Well ran the car today. Its not as bad as I thought. Battery stays around 3/4 charge 44 mpg driving in city.
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    If you are simply looking at the Multifunction display, you are really missing a lot of information.
    I'll say it again....
    With a car like yours you should really consider getting some scan tools. Will cost you less than $30
    Android phone/tablet, Elm 327 Bluetooth OBDII reader, Torque Pro app.
    You'll see much more granular data like State of charge, hybrid battery voltage, Amps in/out, Voltage of each of the 14 Battery blocks, etc
    WilDavis likes this.
  6. 44Zoomer
    35
    Hawaii
    Thanks, It is on order... Just waiting for it. Here in Hawaii takes weeks instead of days.
  7. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I second the suggestion of something like a ScanGauge-II, I have two SG-IIs in my 2009 Gen II, and the 8 X-Gauges are:
    Upper:
    ICE RPM
    WaterTemp (ICE)
    AuxBattery Voltage
    ICE Power (HP)
    Lower:
    TractionBattery (btV)
    TractionBattery Current (+/-btA)
    TractionBattery (SoC) alternating with TractionBattery (cell-delta) (csd)
    Fuel Consumption (for current trip)
    ScanGuage-IIs are a great idea particularly if you're interested in HyperMiling. Also LinearLogic (makers of the SG-IIs) are very helpful, and their customer support is absolutely first class!
    hope this helps - Wil :)
    #27 WilDavis, Aug 2, 2017
    Raytheeagle likes this.
  8. 44Zoomer
    35
    Hawaii
    Yes Yes.......Thank you... Looking it up as I type.. Helps more than ever
  9. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    Glad to hear this! I recommend driving the car for a few days then cycling the pack another time or two. You should continue seeing improvements. :)
    How do you get btV, btA, and SOC on the same screen? When I tried it would only show one or them at a time.
  10. WilDavis
    2,493
    2,155
    49
    Patience, @jeff652 , patience! …I think it took me 2 or 3 attempts to get the 4 X-Gauges I needed all in the second SG-II (pauses to nip outside to snap a pic of the current setup…)
    jeff652 and Raytheeagle like this.
  11. 44Zoomer
    35
    Hawaii
    Thank you for replying and the advice....Much apricated
  12. 44Zoomer
    35
    Hawaii
    Discharger Broke after three uses. Sent back for repair.
  13. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    I've noted that too, drove me nuts for a week then I started tracking the temperature when I parked it. I've found a cold battery shows less charge than a warm one. Working with a lot of Ryono One+ tools I've also found I can ruin a good battery by filling it up when it is cool and then letting it sit in the sun ️ because of that I'm always careful not to park a completely full battery in the sun.
    iPhone ?
  14. 44Zoomer
    35
    Hawaii
    Interesting.........Thanks for the input...
  15. JC91006
    16,936
    8,646
    This happened to me as well, it's a fuse that blew. You could've just replaced it yourself, home depot sells them. They use a 1.5A fuse, if you buy a 2A fuse, it would give you the additional buffer to prevent the fuse blowing again
  16. 44Zoomer
    35
    Hawaii
    I checked the fuse and it was good so they told me to send it in. Great to hear from others. Thanks
    srellim234 likes this.
  17. JMJCATH
    JMJCATH Member
    91
    52
    Here
    Is this only recommended for failing/older batteries or all batteries?
  18. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    Since you haven't been able to charge it in several weeks I'm curious to know how the battery is holding up. Is it still doing better or is it declining in power?
  19. WilDavis
    2,493
    2,155
    49
    Preventative maintenance for all batteries, I would guess! I bought my 2009 Gen II (used) in early 2014, and invested in a Prolong system even though my car was not throwing any codes. I have used the Prolong system regularly (as per instructions) and have noticed that in the past year, the state of charge (SoC) average figure (66%) has been higher than it was in the first year or so of my owning the car. The average fuel consumption is in the upper 40s, the best MPG per fill-up I've seen was in the high 50s and best on one single journey was 61. Of course, I've no idea of what the figures might have been if I had not regularly conditioned the TractionBattery, but at least (so far) it looks like it has been a worthwhile investment! (…but as always, YMMV ;)!) - hope this helps - Wil :)
    BTW: Welcome to PriusChat! (…but beware, PriusChat can be addictive! :eek:)
    Raytheeagle and srellim234 like this.
  20. JMJCATH
    JMJCATH Member
    91
    52
    Here
    I was referring to Jeff's comment about the number of reconditioning cycles, not whether to use the Prolong system on all batteries. That is, recondition, drive the car for a few days, recondition, drive the car a few days, etc. Does this recommendation just apply to 44Zoomer's battery or does it apply to newer batteries as well?
