Prolong Battery Discharger testing
Discussion in 'Gen 2 Prius Main Forum' started by jeff652, Dec 12, 2016.
  1. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    Discharge testing of our soon to be released Prolong Battery Discharger went perfectly. Just need to finalize our enclosure design and ramp for production. Can't want to get this to market!
    The Prolong Battery Discharger will:
    -Be extremely easy to use
    -Work with every vehicle we currently support
    -Drain the battery at 1.4-1.5A during the normal operating range, then taper current draw down as low as 200mA while the battery deep discharges.
    -Shut it self off when done.
    -Have multiple safety monitors & protection mechanisms
    -Retail for less than $200
    Target release is January-February 2017
    (We are also working on a universal pro series 3A charger and discharger that will be released in the spring for our professional customers)
  2. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    Just stack it under the charger in a visually similar enclosure appropriately labeled and leave a reasonable gap for heat to escape. When not in use, the cables could be wrapped around the posts providing the gap.
    jeff652 likes this.
  3. jeff652
    607
    624
    Idaho
    It's going to start off as a sheet metal box. Injection molds are expensive and we want to be sure it's going to take off before investing in molds.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Is that a fan design? If so, will it pull double duty and direct the exhaust air to the HV battery?
    avprius likes this.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Sure sounds alot better than the light bulb routine. I would be interested in one.
  6. gamma742
    gamma742 Member
    178
    73
    Luxury
    Is that it, in the silver enclosure?
  7. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    Certainly an improvement from the light bulb, can I ask how it differs from the intelligent discharger?
  8. jeff652
    607
    624
    Idaho
    Functionally almost identical for 1/3 the price. Internally a completely new design that brings cost down and reliability up. :)
    EDIT: There is one key difference. The Intelligent discharger has a peak current draw of 2.5A. The Prolong Battery Discharger will peak at 1.5A. It will take longer to drain the battery. This is a fine trade off for a product that will be 1/3 of the cost. We are also working on a new Universal 3A Professional grade discharger. One unit that will work with all battery types and be faster (at a 3A peak). It will obviously cost a lot more than the consumer units as well.
    #8 jeff652, Dec 18, 2016
    offib likes this.
  9. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    Thanks that helps, especially in understanding the price difference. The intelligent discharge has worked pretty well for me so far, will be nice to see what the end product (Prolong Battery Discharger) will look like. Consider cooling and ventilation as dischargers typically tend to run hot and some users may be in the tropics with all year round average temperatures in the mid 80's degree centigrade.
  10. jeff652
    607
    624
    Idaho
    Getting closer. Some revisions needed to the enclosure and one more PCB edit:
    We are also adding what I have named the @WilDavis feature :): An audible (loud) buzzer that alerts you when the discharge process is complete. Think microwave on steroids. It's not Bluetooth but will have the same effect.
    I think we will have these ready in late March/early April. It will likely be a limited release initially or slightly higher cost for the first couple months due to a key component being on global back order and all alternatives being much more expensive. :(.
    #10 jeff652, Jan 13, 2017
    Raytheeagle and WilDavis like this.
  11. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Thank you @jeff652 - I feel deeply honoured! :)
  12. dolj
    dolj Senior Member
    8,630
    4,384
    Wellington, New Zealand
    Will it be programable to be able to select it on/off and is the volume level adjustable? Just thinking if I am working away right next to it, I don't really want to be "yelled" at by the thing and possibly jump out of my skin. LOL.
  13. jeff652
    607
    624
    Idaho
    hahah yes, great question. We need a way to silence it for those overnight discharge sessions (and to reduce scare events;))
    Bill the Engineer likes this.
  14. offib
    offib Member
    162
    96
    Dublin
    Four Touring
    Aww man.
  15. jeff652
    607
    624
    Idaho
    Yeah we are not excited about it either. It's only about a $20 impact, but still. It seems we have the last 12 of the spec'd fans on the planet and more won't be in from the factory until mid May. The next best alternative is close to $10 each more
  16. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    That doesn't seem bad at all.
    And won't deter some from looking at that option in the near future:).
  17. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    In my career as a machine design engineer, I have run into similar situations many times before. My advice to you is that time to market is more important than a short term $20.00 premium. Give the customers the choice to get the more expensive first run, or to wait for the less expensive version.
    Considering I have a 2004 Gen II, 2010 Gen III and 2014 "v" donor chassis under the Firebrid, I'm going to be looking for the full discharge/recharge package to use on my fleet soon.
    Bill the Engineer
    offib, Raytheeagle and jeff652 like this.
  18. offib
    offib Member
    162
    96
    Dublin
    Four Touring
    Pretty much.
    I was meant to reply earlier, Jeff. Sorry about that. A $20 or $40 bumb up is acceptable. I was just not hoping for the release date to more from early February to at the most mid May. If it's not now, then I wouldn't be able to devote the time for it until July most likely.
  19. jeff652
    607
    624
    Idaho
    We are opening the Prolong Battery DIscharger for pre-orders. I will add a few prototype photos tonight, mostly the ones from this thread. Here is the link with dates, price, detailed product info, and pre-order details:
    Prolong Battery Discharger Pre-Order -- Hybrid Automotive
    Feel free to ask questions here of via PM/email and I will do my best to answer them.
    Jeff
    offib likes this.
  20. offib
    offib Member
    162
    96
    Dublin
    Four Touring
    Nice!!!! Pretty sure I'll be jumping in on this soon! Looking at the checkout from your site, would it include taxes and all that jazz when importing to Ireland? And would the right, 3-pin inlet be supplied for 230v 50Hz? If not are they the usual female power cables for desktop computers?
    #20 offib, Jan 24, 2017
    jeff652 likes this.
