Prolong Battery reconditioning
Discussion in 'Gen 2 Prius Technical Discussion' started by SBP Mike, Dec 27, 2018.
  1. SBP Mike
    SBP Mike Junior Member
    51
    Chehalis WA
    Working on my grandson's 2005 Prius with 190K miles and original battery. It has been throwing some codes. First one was a misfire code, so we replaced the plugs. All good. Second code was for the hybrid battery system. I think it was P0A80. Check engine light stayed on and I decided to try the Prolong system reconditioning on this vehicle. Priuscamper and I did a pretty serious rebuild job on my 2005 prius earlier this year, so I have some background with this stuff, but not a lot.
    I borrowed the prolong charger and the manual discharge double light bulb device and started by pulling the covers off the pack in the car. Connectors and nuts were not very corroded, so I am not planning to change them at this time. Basic voltage readings on all the cells looked pretty good. None of the cells jumped out as bad, but I did not load test, just a voltage reading on every module.
    I put on the prolong harness and topped the whole pack. I went to 243v and then moved to the discharge stage. I thought I was being pretty careful, but that turned out not to be the case. Special tip: hook up the multimeter to the double bulb manual discharge before you put the bulbs in or attach the manual discharge unit to the prolong harness. I did bulbs and harness first and I created a short with the dangling leads and blew the fuse on the prolong harness. Then I broke the orange shutoff switch when I was working on that. Then I closed the garage and quit auto work for ten days, while I acquired more fuses and replacement switch.
    Went back to the garage and replaced the fuse, buttoned everything up, gently installed the shutoff switch and powered the car up. Everything looking good. All lights gone and the car moves, so that was a relief. I was worried I had blown more than just the fuse on the harness. I started the first discharge carefully and in the right sequence. I had 217v when I started the discharge and I ran it down to 114v with the two bulbs in about 5 hours. I went back to charging and I am up to 222v after 14 hours. I would like to see it get back in the 235v range before I start the second discharge. I think I will only do two discharges, so the second discharge will be trying to get down and stop around 84v.
    I have plenty of time and I want to go slow and not make any more mistakes if possible. I may turn off the charger in a few hours and then turn it back on in the morning. I think I should be patient and keep an eye on charging voltage and let it get higher than the current 222v, but I am open to suggestions and thoughts about the process so far.
    Cheers
    Mike
  2. JC91006
    16,936
    8,646
    You should have taken a voltage measurement of each module after 10 days of non use. The bad modules will stand out like a sore thumb
    Skibob and SFO like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Follow the Prolong recommendation of charging until you see a stable voltage for 4-6 hours;).
    Slow and methodical wins this race :).
    Good luck with the rebuild (y).
    Skibob, SFO and srellim234 like this.
  4. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    I know that when I use my Prolong system, whatever number I get on the first charge and balance phase is the lowest I get on any of the charges. Given the fact that you got to over 240v on the first charge and balance phase, my opinion would be to get it to at least 235-240v before the next discharge. I'm assuming this is the first time the Prolong system has been used on it so it's probably a good candidate for "long soaks" on the charger of 36-40 hours. That should help strengthen the weakest cells in relationship to the strongest.
  5. SBP Mike
    51
    Chehalis WA
    Yes, I missed an opportunity there, didn't I. I was too anxious to close it up and get to the reconditioning after my two mishaps 10 days before.
  6. SBP Mike
    51
    Chehalis WA
    Walked back down to the garage and turned the charger back on. I have been cautious the last two nights and turned off the charger. Maybe worried about overcharging, but I think the prolong charger should take that worry off the table. I think this is the first time this battery has been touched by anyone.
    I hope/plan to hit the 235 to 240v range tomorrow before I run the second/final discharge cycle.
    Thanks to you all.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Module testing without a load test is meaningless.They may all show good surface charge but one or more modules are soft and will decay faster then the other modules under load and the system will then detect a delta and then it throws a RTOD.
    Prolong is pretty useless after the pack has thrown a code so stop prolonging and start load testing individual modules. You have some soft modules. Possibly cracked interior modules. Take them out and look carefully for module electrolyte leakage or any sign of cracks. Once those are found and replaced with healthy batteries then the Prolong can do its thing.
    When done bolt it all back up and put the battery back in the car and begin prolonging.
    Never use a prolong when the batteries are not bolted back up in the case as it will rupture the modules.
    Also the discharge bulb system was sold with a little voltmeter hardwired into the lamp base to prevent the very issue you experienced shorting out leads.
    #7 edthefox5, Dec 28, 2018
    ydpplqbd, DanIL, SFO and 1 other person like this.
  8. SBP Mike
    51
    Chehalis WA
    Initial module test on the pack in my 2005 vehicle clearly indicated one module with a dead cell and the two end modules were also slightly under the range of all the "healthy" modules. All three of these modules looked much worse under load testing and we switched them out and replaced with healthy modules. I get what you are saying about running the load test and I think it is certainly the best practice to get a battery back in tip top condition. I expect to end up doing that with this battery pack, but I am hoping to get six months out of this reconditioning so that I can do the real rebuild of the pack in a month with warm rainfall instead of the cold rain we get here in the PNW in the winter.
    Ideally, I will be able to pick up an extra battery pack in the next few months, load test it, replace the bad cells and then just switch this battery pack out. I have friends with Gen 2 priuses, so we are all working toward this goal of having a rebuilt pack handy for quick install. We just need to get a pack or two ahead to make this work. So far, we have been on our heels a bit responding to packs with issues instead of getting on our toes with a couple of extra good packs.
    I checked a couple at 6:30 am and I was at 229v. What do we want? Patience! When do we want it? Now! Hope I will get up to 238-240 later today and stabilize at some value in that range. Following raytheeagle's sage advice on this charge up.
    edthefox5, TomB985 and Raytheeagle like this.
  9. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Let it charge for at least 30 hours. It will really help. Patience.
    It takes a long time @.338 amps to fully charge 28 packs in series. Long time.
  10. Athos
    Athos Junior Member
    Ontario, Canada
    I have the Prolong system with the discharger that has three shut-off levels. I always top charge first but never do a long soak on the first charge. Also, on the first discharge I don't go too low. After the second top charge the cells are much better aligned so there is less risk of cell reversal when you go lower on subsequent cycles.
    Here's my question to the group. I'm lazy. I could load test each subpack individually but that takes work, time and introduces some variability. Does anyone know an easy way to load the whole pack at once? Then I could test the voltages quickly with a meter. I realize there would be a rebound but I might be able to factor that in.
    Thanks, people. I'm migrating over from Hondas and am just learning the Prius. The Honda packs are such a pain! I'm having much more success with the Toyota packs.
    edthefox5 likes this.
  11. dolj
    dolj Senior Member
    8,634
    4,388
    Wellington, New Zealand
    I'm not sure I understand your post.
    For someone who confesses to being lazy, you have outlined a lot of work the Prolong charger/discharger is designed to eliminate.
    Why would you want to load test the whole pack, anyway? You can get that kind of data using Dr Prius or even Torque Pro or Techstream.
    ydpplqbd likes this.
  12. Athos
    Athos Junior Member
    Ontario, Canada
    No, I don't want to load test the whole pack, rather, I wanted to load the pack then quickly take the voltage of each subpack. This pack was brought to me to try to fix and it wasn't in a car.
    I ended up doing individual load testing on each subpack. Not that hard really, I just wanted to save a bit of time. Because the pack had been worked on by the owner I had a hard time identifying the problem subpack. I ended up cycling the pack then doing the load testing after it was half discharged. That caused one subpack to stand out as bad.
    Here's the setup I use for cycling a pack that isn't in the car. I use a fan and duct from a Gen 1 Honda Insight.
