Prolong charger fixed me again even though I do it wrong:
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by edthefox5, May 28, 2019.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    About 16 months ago my bought new 07 was showing hybrid battery issues. Going to purple real fast and bad mileage and no power. Bought the prolong charger the original one with the light bulbs and did a full or so i thought discharging session. I did it wrong but it came out really well. I DO NOT charge between discharge sessions.
    Now 16 months later she's getting tired so i did another session.the same way. Here's how i do it:
    Charge the battery for 24 hours. Then begin discharge session by installing dual 200 watt bulbs. I let it discharge to 180 volts. Then I changed out the bulbs to dual 75 watt bulbs. I do not charge between discharge sessions. I run the dual 75 watt bulbs till it hits 85 volts then i changed them out to dual 25 watt bulbs till it hits 50 volts.
    I then stop discharging and begin re-charging and let it charge for 24 hours.
    It works really really well and its fast i can do it over a weekend.I think its a much more benign discharging session and does not invoke alot of heat. The battery was still healthy enough to respond to another discharge session.
    Battery is awesome again. Solid 3-4 blue bars wherever I go and whatever style I drive. back to 50 mpg's.
  2. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    You're bringing the cells down to 0.3V per cell??? That can't be right... That's a super bad idea. All for reconditioning batteries and Prolong makes an excellent system, but 0.3V is way into the permanent damage area of NiMH cells.
    SFO likes this.
  3. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    The 17V setting on the intelligent discharger should bring the pack down to 0.1V per cell... Is that not so intelligent?
    Pixel XL ?
    edthefox5 and SFO like this.
  4. edthefox5
    10,096
    4,837
    Clearwater, Florida
    I would never argue with you about battery’s 2k as you know much more about them then I do but I can tell you my battery responds incredibly well with this method. Been a month since the second rejuv and it’s like a new battery. I suspect that will not last as long as the first rejuv session though as I know I am on borrowed time.
