Prolong Charger - Voltage Decreasing
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by JMJCATH, Jun 17, 2018.
  1. JMJCATH
    JMJCATH Member
    91
    52
    Here
    Has anyone else experienced their voltage going down while using the Prolong charger?
    I am in the process of charging the battery. After charging for 20hours, the voltage was at 238v and then at the 24 hour mark, it went down to 235v . The hybrid battery fan is running, ambient temperature is around 85 degrees, and the amps appear to be constant. No associated discharge was done at this time; only a hybrid battery charge. Anybody?
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Yes, but I had a different situation and ambient conditions.
    You might give it some more time and see if it balances upwards again.
    Otherwise jump into the first discharge cycle, and play catch up on the next (or final) charge/balance cycle.
    How many miles on the HV battery?
  3. JMJCATH
    JMJCATH Member
    91
    52
    Here
    It's on a 2012 V with 40K miles. I've discharged it twice and charged it about 6 times. Unfortunately, I can't discharge it right now since I need the car until July.
  4. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Seems a little early in your batteries life for a single reconditioning, much less multiple times :confused:
    Why do you feel the need to continually recondition a relatively new battery with only 40k miles, did something happen?
    Raytheeagle likes this.
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    OP only has 40k miles; that's about a 5k/yr average which is not good for HV battery longevity. BTDT Agree about the number of sessions, probably should ask prolong for guidance.
    On the voltage concerns, from the prolong website: "During the 'balancing' phase you will most likely see a steady voltage reading or a very slow oscillation of voltage - perhaps a 1-3 volt swing over several minutes. This means the battery is in the balancing phase".
  6. JMJCATH
    JMJCATH Member
    91
    52
    Here
    Because of Prolong's advice, found in their FAQ's, "Even if one were to have to eventually replace part or all of the hybrid battery, a Prolong Battery Reconditioning Package is still a good investment as it will prevent the replacement hybrid battery from returning to the deteriorated state of the current pack. We have many customers that are buying brand new hybrid battery packs and adding a Prolong Battery Charger on day one to eliminate the chance of cell imbalance returning."
  7. JMJCATH
    JMJCATH Member
    91
    52
    Here
    The voltage wasn't oscillating at all, nor was it oscillating over several minutes. It was continuously going down.
  8. JMJCATH
    JMJCATH Member
    91
    52
    Here
    Raytheeagle, SFO and fotomoto like this.
  9. fotomoto
    5,639
    3,815
    So. Texas
    Ahh. I'd say then it's time to stop if you've been at it for 24+ hours. My guess is it's just a temperature thing as my peak voltages were consistently lower during warmer months. Check with jeff and report back please.
    Raytheeagle and SFO like this.
  10. taxibuddy
    taxibuddy Member
    79
    57
    Atlanta
    2014 Prius v wagon
    Is this a Toyota battery with a Toyota warranty?
    SFO likes this.
  11. Joeman200
    Joeman200 Junior Member
    South Carolina
    Resurrecting this old thread instead of starting a new one. I'm having the same issue. I was in stage 2, dropped to 101 volts and started to recharge. Gained the first part back in decent time, then took around 24 hours to go from 230 to 242volts. Over the past 4 hours, my voltage has now slowly been dropping to 235volts. Thoughts? I may just start my discharge cycle.
  12. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Best to start your discharge (after a cool down), as the instructions mention not to charge for over 24hrs (unless that has changed).
