Prolong Charging possible Issue?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mjaajm, May 27, 2019.
  1. mjaajm
    mjaajm Junior Member
    Michigan
    Rebuilt my Prius battery. Replaced a 2 module. Sorted modules inside to outside. All 28 cells tested at 7.8v. Placed back in car and installed Prolong wiring harness then hooked up the Prolong charger per instructions and it started. It went just as the procedures read. Fans on voltage wavered for a moment all looked good. The charger read 202V and .004A and has not changed in 7 hours.
    2 things, 1) if all individual 28 batteries confirmed at 7.8v shouldn't it read 218.4v and 2) .004A - isn't that too low to charge anything? My fear is that it is not charging anything at this time. Any insights?
    <this is actually written by my husband who is trying very hard to keep my beloved Prius running for me. It threw the triangle of death and the hybrid battery error just after turning 250k. We opted to replace modules (only one was showing as bad) and try the charger. One round of whack-a-mole and then we make a bigger decision of this doesn't work>
    Prieth likes this.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    You are correct, I'd agree that something is wrong. The last I knew, the charge rate should be around 0.350 amps, which is about 90x what you say yours is showing. Did you get the discharger also?
    jerrymildred likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Is the hybrid battery fan running?
  4. mjaajm
    Michigan
  5. mjaajm
    Michigan
    Yes. We got the discharger
  6. TMR-JWAP
    6,404
    6,099
    Columbia, SC
    try using the discharger for a few minutes. Just to see if it functions correctly. That would at least verify whether its a device issue or a battery/wire harness issue (open circuit).
    With the charger not putting out any amperage, the possibility exists you could have an assembly problem on the battery, a connection problem with the harness, a bad harness, or a bad charger.
    If the discharger functions correctly then I would say the battery assembly is ok, the harness and it's connection would also be ok. That leaves only the charger to be faulty.
    Prieth and Raytheeagle like this.
  7. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Are you sure the orange disconnect plug is properly installed?
    Prieth likes this.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    The charger is not pulling any current should be showing .338 which is 338 milliamps.
    The charger is clamped at that regulation so it charges pretty slow so not to invoke heat. So I think Ski may be right the safety plug is not installed properly. You insert it fully then flip up the handle then push the handle down till it locks. Everyone forgets the push down part.
    My ammeter on my charger goes crazy after a full discharge and battery voltage is very low it shows wild fluctuations between 0 amps and .338. Flips back and forth real fast. It settles in after a while when the battery voltage reaches 150 or so volts. Freaks you out first time though.
    You have to charge it for at least 24 hours maybe more to get full benefit.
    Skibob likes this.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    SFO and Raytheeagle like this.
  10. jerrymildred
    11,517
    14,171
    Tampa, FL
    So, @mjaajm (or husband), did you get it working?
  11. TMR-JWAP
    6,404
    6,099
    Columbia, SC
    For those that want to know....the orange safety plug provides FULL electrical continuity as soon as it's pushed in about 2mm. The fuse makes contact and full voltage is available at the battery side of the relays. Pushing it further in and rotating the handle upward merely ensure full 100% contact and locks it in place. Pushing the handle straight down does NOTHING for continuity or locking it in place, it merely installs a jumper across the safety circuit contacts so the ECU knows the safety plug is installed.
  12. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Ok but how come we see so many posters who have inserted the plug but have not
    Pushed the lever down and dead in the water.
    That’s a lot of posters that get fixed by pushing the lever down.
    Listen I have never been inside the pack just trying to learn so take it easy.
  13. jerrymildred
    11,517
    14,171
    Tampa, FL
    That's because, if you don't slide the handle to its proper position, you don't close that jumper that @TMR-JWAP described and therefore the ECU thinks the disconnect is still open.
    Skibob and Prodigyplace like this.
