Sold Prolong Deluxe Charger & Discharger $475 used only once!
Discussion in 'Private Sales' started by Totallylost, Feb 26, 2019.
  1. Totallylost
    Totallylost Member
    46
    42
    silver springs
    . prius.jpg Prolong Deluxe Charger & Discharger (in mint condition) 2nd Generation. Located in Central Florida. $475.00. Used only once.
    Raytheeagle and SFO like this.
  2. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    Yay! You got it listed. Here's hoping it finds a good home.
    Totallylost and Raytheeagle like this.
  3. richmke
    richmke Member
    73
    48
    Milwaukee, WI
    You might want to say whether the harness is included or not.
    Totallylost likes this.
  4. jerrymildred
    11,491
    14,100
    Tampa, FL
    Since it's in the picture, I'd assume so, but yes, it would be nice to make that abundantly clear. (y)
  5. Totallylost
    Totallylost Member
    46
    42
    silver springs
    Great suggestion! :) Yes, if the harness is the cable thingy? lol (totally lost -that's me!) but I will take pics later today of the actual unit and everything and will upload here. thanks
    jerrymildred likes this.
  6. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    Interested! PMED!
    jerrymildred and Raytheeagle like this.
  7. padroo
    padroo Senior Member
    2,763
    2,250
    I'm assuming you sold your Prius? Good luck on your sale.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    If you want to purchase a harness and get in on the Bay Area shared Prolong system, that might be another way to do it;).
    But if you buy your own, this is a good deal(y).
    SFO likes this.
  9. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    Hey! I know you guys have dealt with these things. Could you tell me if this harness is broken? Someone messaged the poster told him this.
  10. jerrymildred
    11,491
    14,100
    Tampa, FL
    @jeff652, is that some sort of quick disconnect for the battery terminals?
    Raytheeagle likes this.
  11. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    It just so happens I have a spare harness here at the house that is part of what we share for the Prolong equipment:
    So to me it looks like one of the leads is missing:
    You could probably get that from @jeff652 (y).
    SFO likes this.
  12. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    Thank you! Is it something that is something that I'd need to get a new harness or something that can be replaced (fixed)
  13. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    Fixed as I bet those are just lying around at the shop where the harnesses are assembled ;).
    SFO likes this.
  14. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    Thank you, I'll email Jeff and ask him how much it would cost me! Appreciate you guys!
  15. jeff652
    jeff652 Senior Member
    597
    623
    Idaho
    SFO, jerrymildred and Raytheeagle like this.
  16. richmke
    richmke Member
    73
    48
    Milwaukee, WI
    To expand on what Jeff said:
    The Black Cap is the fuse holder, and is the red wire.
    The black wire is also cut short.
    Both will need ring terminal connections as shown in Ray's 2nd photo.
    Looks like they didn't want to spend 10 minutes to remove the left side panel and back seat, so they could get to the terminal cover and remove it.
    FYI: If the car is still being driven, the wires need to be removed or properly capped. You don't want those wire accidentally shorting against anything.
    SFO likes this.
  17. 04priusnow
    04priusnow Active Member
    345
    201
    hi still have the charger? what prius year is the harness for?
    Thanks
    PH-1 ?
  18. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    2004-2009 as it is a Gen2 ;).
  19. jerrymildred
    11,491
    14,100
    Tampa, FL
    Nice catch, Ray! The very first picture was a little small and indistinct and I had forgotten about the fuse holder. Super easy to fix, but I agree that if there are cut-off wires connected to the battery, they need to be removed for safety right away. Probably, the worst that would happen is a ground fault that would shut down the car, but a shock isn't out of the question.
  20. Totallylost
    Totallylost Member
    46
    42
    silver springs
    Hi :) thank you! We just shipped out the harness so it's all good. It is an easy fix we have been told.
