Sold Prolong Deluxe Charger & Discharger $475 used only once!
Discussion in 'Private Sales' started by Totallylost, Feb 26, 2019.
  1. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
  2. Totallylost
    Totallylost Member
    46
    42
    silver springs
    hi :) looks good. Perhaps the manufacturer (Prolong/Jeff) or Raytheeagle. But I will ask around and let you know.
  3. Totallylost
    Totallylost Member
    46
    42
    silver springs
    Hello: asked my boyfriend. He says that based on what he is aware of, those 3 items may work but regarding the first item (fuse) he would does know the correct amperage. And that checking with the manufacturer (Prolong/Jeff), he should be able to give you that info. And the 3rd item he says that only half of the fuse connector is what you would really need. Just make sure it matches and again better to confirm (or acquire one) from manufacturer.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,143
    Tampa, FL
    He has already given that info:
    SFO and Raytheeagle like this.
  5. Tyoder
    Tyoder New Member
    NC
    TotallyLost, do you still have the Prolong reconditioning package, & did you ever answer if it includes the wiring harness? If so, I'm interested.
    Everyone else, I need some advice. My '05 prius has 207k miles on it. The red triangle lights & all that normally accompany it came on & the code was the 1 saying the inverter pump needed to be replaced. So I replaced it, & the lights went off for a while. They came back on shortly after, & I thought it was for the same reason, but checked the pump & all was cooling fine, so I started driving it. Yesterday, driving home from work, the car started doing some crazy things. First, it revved high going down interstate & started slowly accelerating/maintaining speed on it's own. So I shifted to neutral to see if that would help the revving, but it did not. Once I shifted back to drive, I press the gas, & it doesn't accelerate. So I pull of the side of the road, turn the car off, crank it right back up, & it takes off as it should. I should also mention that during all of this, the air intake fan for the battery has been running this whole time & continued to run the rest of the drive home. Before I made it home, it did all of this again. Got the codes read & I have c1259, c1310, p0A93, p0A80, & p3020. Based on these, I'm pretty sure my HV battery needs replacing/reconditioning.
    My question is, will this prolong charger resolve my battery issues, or should I have it replace with another battery all reconditioned? I bought the car with 107k miles on it & now it has 207k miles on it, & I've never done anything to the HV battery. Realistically, what am I looking at in terms of success rate with trying a prolong charger?
    Thanks in advance for the help.
  6. Phildo
    Phildo Active Member
    138
    109
    Perth, Western Australia
    i-Tech
    The P3020 code indicates that one of the modules in block 10 is stuffed.
    This thread covers what you need to do: https://priuschat.com/threads/gen-ii-prius-individual-battery-module-replacement.125588
    In short:
    - Remove battery from the car, and test/assess each module (ie discharge/charge each module three times, and then load test it).
    - Modules that have too low capacity, or fail a load test, get replaced with compatible modules (eg similar age and capacity).
    - Then a Prolong setup will be ideal to ensure that the modules are all balanced.
  7. Prieth
    Prieth Junior Member
    17
    NM, USA
    I expect this is sold, but if you still have it for sale please let me know.
  8. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Raytheeagle likes this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,264
    15,515
    Bay Area, California
    2019 Prius Prime
  10. framistat
    framistat Junior Member
    43
    Fairport, NY
    Please mark as SOLD.
