Prolong wiring modification
Discussion in 'Gen 2 Prius Technical Discussion' started by 99homeruns, Jul 11, 2018.
  1. 99homeruns
    99homeruns Junior Member
    NC
    I have a prolong for my Honda Civic and I want to modify existing wiring harness to work with my 07 Prius. I know they can be purchase but I would rather modify it myself. Any suggestions?
    #1 99homeruns, Jul 11, 2018
    SFO likes this.
  2. 99homeruns
    NC
    I have the plugs that go to the battery. I cut them out of a car at the junk yard. I was hoping to splice the plug going to the fan.
  3. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    Didn't think the Honda charger would work on a Prius. Don't they have a different number of cells in their respective batteries?
  4. 99homeruns
    NC
    The Prius battery is more voltage and has more cells. Hybrid automotive sells a package with one charger and wiring harnesses to fit almost every hybrid in one package. So I assume a charger will adapt to any car as long as you have a wiring harness that will function.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    I think you're referring to the Pro system. For the consumer ones, there is a different model for each voltage.
