Propane smell inside 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by KJF, Nov 20, 2017.
  1. KJF
    KJF Member
    75
    17
    Small town - north central Idaho
    After my 2010 Prius sat unused for about 10 days, the interior smelled heavily of propane. I understand that propane is colorless and odorless and that it only smells due to the ethyl mercaptan added to it. There is no propane in the Prius (I did call my dealer and they verified no propane and they had never heard of such a thing). I smelled the hybrid battery vent on the passenger side of the back seat and it does not seem to be originating from there. Could something in the car be deteriorating that would create ethyl mercaptan or a smell like it? After using the car since, I still smell this but not as strong. Any comments would be appreciated.
    #1 KJF, Nov 20, 2017
  2. sillymike
    sillymike Junior Member
    59
    GA
    Check for a shrimp wheel left in the trunk. My brother once forgot he left a shrimp wheel in his 5 day old audi s7. In the south florida summer sun. Never got the smell out. Probably some food somewhere under the seats.
    KJF likes this.
    52,886
    mold in the a/c is one suspect. another is vent tubes for the hybrid battery, although, i think that was gen 2.
    i don't recall anyone ever mentioning a propane smell before.
    another possibility is vermin, they like to build nests in the air intake or cabin filter area.
    and of course, stale food, as mentioned above.
    time to pull everything apart and search it out, all the best!(y)
    KJF likes this.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    A dead organism is the most common cause of weird smells.
    Or does it smell more like rotten eggs which is usually a battery venting or the catcon when the car is running?
    KJF likes this.
  5. KJF
    KJF Member
    75
    17
    Tomorrow I will look for something dead or food and will also dive into both batteries to see if they seem to be venting - definitely a propane smell - not rotten egg smell. Will report back after my deep dive...
    Mendel Leisk and bisco like this.
  6. bisco
    52,886
    check your cabin filter too.
    KJF likes this.
  7. Mendel Leisk
    42,368
    Do you have kids? Somebody tucked a snack away, for later?
    KJF likes this.
  8. KJF
    KJF Member
    75
    17
    Will check cabin filter and under the hood. No kids - just me - so pretty sure it is not food.
  9. HomeyClown
    HomeyClown Junior Member
    31
    23
    Austin
    I
    #9 HomeyClown, Nov 23, 2017
    KJF likes this.
  10. Mendel Leisk
    42,368
    Second gen vent tubes were smelling bad, but AFAIK no repeat of the problem with 3rd gen. They wised up, changed suppliers?
    KJF likes this.
  11. KJF
    KJF Member
    75
    17
    I have not yet located the propane smell but I have caused myself Considerable Trouble while learning some things in the process. While systematically going through my car and removing and smelling every thing, I exposed (for the first time) the back side of the hybrid battery case. The orange plastic plug on the right side had a handle on it so I pulled it and removed it to look at it, and then put it back. The 12 volt battery looks good and clean and its vent is in place and functioning and does not smell. I ran out of time to go further since I had to go to work. Much to my surprise and dismay, the car started but would not go into reverse or drive and I had a large "Check Hybrid System" on the dash display. I had no time to go back in the house to search PriusChat so borrowed another rig to get to work. Later research showed me that I had not completely replaced the orange plug (it needs a slide to the right to fully lock it in place) and that the orange plug disables the hybrid system (one person said it would be a good theft deterrent - I agree!). So I properly replaced the plug and the car did start and go except I still had the "Check Hybrid System" on the display along with the large triangle with an exclamation point that would not go away. Back into the house to dial up PriusChat - the advice to start and stop the car three times in a row did the trick and the displays cleared. Next is further exploration of the hybrid battery area and the battery fan. Stay tuned. And thanks for being such a good resource for us uncertain DIYers!
    bisco and Mendel Leisk like this.
  12. KJF
    KJF Member
    75
    17
    Update on Propane Smell in 2010 Prius with a deep dive search and smell into almost everything without discovering the source! Searched/smelled (s/s) under hood, s/s interior, all items in car, under seats, removed glove compartment and cabin filter (cleaned not that long ago and still clean), s/s and removed everything from rear hatch including spare tire and tools and warm clothes and emergency stuff, 12 volt battery clean with no corrosion and vent tube intact, exposed hybrid battery fan and cleaned it (not dirty at all) , removed/cleaned the air vent to the hybrid battery (passenger side of back seat) as well as the black plastic vent from the battery, removed metal cover for the hybrid battery (after disabling it with orange plug), very little corrosion on hybrid battery metals (decided not to use anything other than an old toothbrush - nothing to speak of brushed off - felt too risky to use boric acid or vinegar or baking soda, etc under the "if it ain't broke, don't fix it" rule), verified that the rubber venting tubes running along the top of the cells were clear and venting through tubing to the exterior of the car. I did this over the course of several days and the propane smell lightly persisted. Got it all put back (nothing left over) and then jacked up the car 5 different ways to get underneath to smell and search for anything dead or melted or stuck underneath. The smell clears upon use and does not seem to be coming through the fresh air vents but I am considering borrowing a leaf blower and forcing air through the fresh air vents without the car running to verify nothing stinks in there, My only other thought is something could be under the plastic panels on the bottom of the car. I would want to have use of a lift to undo all that...
    After much searching on the Internet, I found cases of GM vehicles that had a propane smell coming from the transaxle and it was solved by venting it more towards the back of the vehicle.
    I wanted to give an update as it drives me nuts when someone posts about the same problem I am having and then never gives us the rest of the story...any comments or other ideas appreciated.
  13. Mendel Leisk
    42,368
    I wouldn't dive to deep, especially with items like the hybrid battery, if you're not detecting any odor as you get close.
    Pop the rear seat off? That might be a red herring too: I keep thinking kids pushing leftover in there, but you've nixed that. Hmm.
    KJF likes this.
  14. KJF
    KJF Member
    75
    17
  15. KJF
    KJF Member
    75
    17
    No odor anyplace that I delved into, including around the hybrid battery. No kids but I like your seat idea. I did not remove the backseat previously but looks easy to do - will do so and report back.
