Protecting the doors and garage
Discussion in 'Prius v Accessories and Modifications' started by Mike James, Jun 14, 2017.
  1. Mike James
    Mike James Camaros and Prii go figure
    142
    35
    Lincoln, NE
    My latest creation to protect the doors and garage wall from smashing into each other as we enter and exit the Prius. 1497491229339.jpg 1497491243710.jpg
  2. Mike James
    142
    35
    Lincoln, NE
    52,877
    very creative, well done!(y)
    Mike James likes this.
  4. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    Pool noodles have so many creative uses!
  5. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
  6. Kenny94945
    Kenny94945 Active Member
    864
    439
    Sausalito
    2016 Prius v wagon
    Nice...
    attractive garage addition.
  7. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    I'd recommend PVC rather than the heavier metal pipe.
    Air_Boss likes this.
  8. Mendel Leisk
    42,361
    Just another data point. And yeah, it's happened more times than I care to admit. :oops:
    jerrymildred, bisco and Air_Boss like this.
  9. Air_Boss
    4,259
    1,197
    New Yawk
    Murphy's Law applies generally, and liberally..
    jerrymildred likes this.
  10. bisco
    52,877
    good one mendel. i have block foam taped to mine, but yours looks cleaner, and makes more sense.
    i just lowered the door the other day with the hatch open for the bajillionth time. no more scratches, but i'm wondering when the spoiler is going to fall off.
    Mendel Leisk and jerrymildred like this.
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Looking back in my car's service history, I see that the spoiler was already replaced by the PO and the replacement damaged by the PO. It got further damaged by the other "PO," aka the Present Owner or the Po'd PO. :oops:
    This mod won't protect me from closing the door on myself, but at least the spoiler doesn't bang and drag on the open garage door now. And I've made a cord I can quickly attach to keep the hatch from going all the way up if I'm going to have the hatch open for a while.
    Mendel Leisk and bisco like this.
  12. bisco
    52,877
    lol, that's a good one jerry. necessity is a mother...:p
  13. Mendel Leisk
    42,361
    Yeah, just assume you'll screw up, and you can't go wrong.
    jerrymildred and Air_Boss like this.
  14. Mike James
    142
    35
    Lincoln, NE
    PVC would sag with a 5 ft length. 10 ft of 1/2" emt only costs $2.74 at Menards.
  15. Air_Boss
    4,259
    1,197
    New Yawk
    Use schedule 80 PVC or take out the sag by pre-stressing lighter PVC with slightly offset end clamps!
  16. Mendel Leisk
    42,361
    maybe an alternate design could skip the pipe, fasten the foam tube directly to the wall? Maybe split, a half-round section?
  17. bisco
    52,877
    what's wrong with metal pipe, will the weight cause the garage wall to collapse eventually?
    #17 bisco, Jun 18, 2017
  18. Mendel Leisk
    42,361
    It's reducing clearance a bit.
    My thought would be to use a half-round with OD same as foam tube ID, and split the foam in half. Then screw through the wood and countersink fairly aggressively into the foam with oversized washer.
    #18 Mendel Leisk, Jun 18, 2017
  19. Mike James
    142
    35
    Lincoln, NE
    That's what my original design was but it doesn't stay stuck to the wall. The glue fails or the tape dries out.
    bisco and Mendel Leisk like this.
