Proximity sensor and door lock/unlock does not work
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by kenp11, Feb 6, 2015.
  1. bisco
    52,880
    maybe that's the problem.:cool:
  2. kenp11
    kenp11 Junior Member
    74
    Orange
    2014 Prius Plug-in
    The dealer found the problem. Connection was loose at the computer. So where are these computer cable connections? Under the dashboard?
    Under the hood? I don not see any near the door except a wire harness roll
    Chazz8 likes this.
    52,880
    wow, that's surprising. i don't know where everything is located. did they charge you?
  4. kenp11
    74
    Orange
    2014 Prius Plug-in
    No..all under warranty. Maybe someone messed with cable during service.
    rxlawdude likes this.
  5. bisco
    52,880
    that's good. any idea how long it took? if it's under the hood, it should be quick. inside the dash is usually time consuming.
  6. kenp11
    74
    Orange
    2014 Prius Plug-in
    I was in and out in 10 minutes. Dealer probably has a computer or tool that can check where the electric connectivity stops from both sides of the sensor handle to computer terminal
  7. boundformexico
    boundformexico New Member
    2015 Prius Plug-in
    I didn’t even know my car did this! It’s like finding $20 in an old pair of pants.
  8. bisco
    52,880
    i love when that happens!:)
  9. Pepe Bono
    Pepe Bono New Member
    Seville
    Design
    Should be a problem with the wiring harness crossing the door towards inside the vehicle? Probably a twist wire could be cut?
