PSA: 14" wheels do not fit on a 2nd Gen Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by 4goodcaws, Aug 9, 2020.
  1. 4goodcaws
    4goodcaws New Member
    Wisconsin
    I have recently been on a search for used winter tires and wheels for my 05 Prius. I came across quite a few sets of tires on 5x100 14" wheels so I went to the forum to see if anyone knew if these might fit. I found lots of posts asking if 14" wheels would fit, but no definitive answers. I even called the dealer to see if they might know the answer and they told me to "check the prius chat forum." So I decided to just try them on and find out for myself. Turns out 14s DO NOT FIT over the brake calipers on the front of a second gen prius (they will fit on the back withe drum brakes). It was pretty close and it may be possible that a low offset 14" wheel would clear the caliper, but you would probably start to hit the fender at that point. There are probably not a ton of people trying to put 14" wheels on their car, but maybe this will help someone.
    2Fats and SFO like this.
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    oem 15" wheels shouldn't be too hard to find anyway.
  3. OwlsOwlsOwls
    OwlsOwlsOwls New Member
    Chicago
    You're the hero I needed today.
