PSA: Change your 12 volt battery every 4 years
Discussion in 'Gen 3 Prius Main Forum' started by RaZa, Aug 24, 2016.
  1. Piotrus Pan
    Piotrus Pan Member
    126
    46
    Luxembourg
    I don't think you understand the problem with your so called test so I'll explain. Since new and charged battery has 12,8V, the inverter puts out 14,3V that means you always will have a speed difference in closing windows. That means you will mark every battery as bad, even the new ones.
    #101 Piotrus Pan, Sep 18, 2016
  2. fjpod
    fjpod Member
    419
    72
    New York
    I'm not so sure that is good advice from an economic and environmental aspect. I have never had a battery last me less than six years and I live in the northeast. Some I've had, have gone 8. Do we really want to over-consume like that? What's the point of buying a Prius in the first place?
    In a warm weather state like Florida, if your battery went dead overnight with no warning, you more than likely left a dome light on (I did it once).
    Silver Pine Mica and Raytheeagle like this.
  3. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    There is a simple way to know if the 12V is dying with out doing anything but listening. When you turn off the car you ever notice that buzzing sound you hear from under the hood? When it starts to sound like an old dial up 56K modem you will be needing a new 12V very soon. I remembered hearing that particular sound about a month before the twelve volt died.
    Tbkilb01 likes this.
  4. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    Yes, 42-48 months for a 12V battery has been my experience in a hot climate. According to the US map below, even that's optimistic:
    http://www.tiresplus.com/img/global/TiresPlus-Battery-BatteryExpectancyZone.jpg
    #104 BruceInOKC, Sep 25, 2016
  5. grnd0
    grnd0 Member
    42
    26
    Well, I live in one of those red areas and have had a few brand new cars and each battery lasted over 5 years. Kind of disproves that theory.
  6. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    now THAT is, with all respect, nothing but BS/
    I live in the 'hot zone' in New Mexico & have the same battery in my GTO since 138 month (that's 11 &1/2 years).
    the battery in my wife's Subaru is 90 month (7 &1/2 years) old.
    the last time I checked them with a load tester was like a couple month ago: both showed perfect numbers.
    it would be an odd coincidence that I just have two freak batteries which last so long....
    BION
    StarCaller
    Raytheeagle likes this.
  7. grnd0
    grnd0 Member
    42
    26
    #107 grnd0, Sep 26, 2016
  8. bisco
    52,858
    nope, you still get 12 months pro rated, no matter where you live.
    i suppose if you're going to give people battery advice to help them not get stranded, a map like that is useful. fortunately, for those savvy enough to keep an eye on things, batteries, and many other products subject to wear and tear can last a lot longer than 'average'.
    #108 bisco, Sep 26, 2016
  9. RaZa
    RaZa Member
    480
    93
    I see a lot of people talking about trickle charging, and again I just feel the need to warn people to make sure you are not putting a trickle charger on an AGM battery. I believe stock batteries are traditional lead acid but a good quality replacement like a yellow top or the one I bought are not. A trickle charger will destroy them...
  10. StarCaller
    1,284
    733
    urban myth or just your own theory ? :D :LOL:
  11. la9ers
    la9ers Junior Member
    37
    Sears actually has a craftsman meter on sale for $10...
    Sears.com
  12. RaZa
    RaZa Member
    480
    93
    a glass mat battery is not charged and maintained the same way a generic lead acid battery is. if you want to throw a trickle charger on it, yes it will charge, but eventually you'll have a dead battery and possibly a fire if you leave it on there if the charger outputs too much amperage (as also stated by optima). do and believe what you want
    #112 RaZa, Oct 1, 2016
  13. StarCaller
    1,284
    733
    best thing would be you let optima know about all that things:
    [email protected]
    looks like you know more about their batteries than they do/ (y)
  14. CR94
    CR94 Senior Member
    2,830
    1,243
    Northwestern S.C.
    That misses the point. Of course there'll be a difference in speed even with a good battery, as you say. However, the difference will be much more obvious with a battery that's on its last legs---even if its open-circuit voltage looks OK.
  15. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    #115 BruceInOKC, Oct 10, 2016
  16. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    After four years? Even on cars which crank the engine to start, I've generally kept batteries at least six years or longer - until they start having starting trouble. And I live in cold Wisconsin.
    The Prius is different, of course, because the 12v battery is not used to crank the gas engine, but to run the computer and other electronics. I put in a new 12v battery after around seven years (bought it from the dealer) because it was at about half capacity, and used the old 12v battery for solar storage for the last year. (It died only yesterday, after powering our living room lights over the last year.)
    CR94 likes this.
