PSD Functioning
Discussion in 'Gen 3 Prius Technical Discussion' started by ingenia, Feb 16, 2011.
  1. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    Toyota calls it a clutch in the 2010 repair manual.
  2. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Regardless if it is a clutch or not, it doesn't even function within the hybrid synergy drive, only within the HVAC.
    You could argue the Prius has many clutches, when in fact, it doesn't have the device commonly understood to be a clutch, only things that are technically understood to be clutches.
    Just because there is a clutch in the HVAC, does that mean you can go around and say "The Prius has a clutch"?
    By the same token, if the AC clutch in a 2010 Ford Focus broke, would I go to the mechanic and say "The clutch is broken in the Focus"? I wouldn't.
  3. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    I think EVPV is Tpfun.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    I see it now. Without seeing the other side, it is hard to tell. So there is another planetary gearset in the differential.
  5. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    qbee42 said:
    "There is no clutch anywhere in a Prius."
    So I posted photos of the torque control clutch attached to the flywheel. And then I said the AC compressor has a clutch in it, with a little smiley face next to my post. Then he said I was wrong. So I posted a page from the 2010 Prius repair manual showing that Toyota calls it a clutch.
    Just some fun with semantics, not WWIII. :hug:
  6. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    I see. You are indeed technically correct.
  7. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    This statement started it all.
  8. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    Yep, I was wrong about that. I saw that video before buying my Prius, I was primarily interested in learning how the epicyclic gears functioned so I didn't pay a lot of attention when the instructor started talking about the flywheel, clutch, pressure plate. No big deal. I learned something and the OP got his answers. Relax.
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    You forgot the clutching that goes on at Lookout Point.
    Tom
