Pulled over for "high-beam"
Discussion in 'Gen 2 Prius Accessories & Modifications' started by weixulu, Oct 26, 2014.
  1. weixulu
    weixulu Junior Member
    NJ, USA
    Last night I got pulled over because the officer thought I was using high beam. I showed him what my HID low-beams look like and he let me go.
    No tickets. Fine. But it is getting annoying. My headlights (4300k Philips D4R Xenon HID Headlight Bulb) are too damn bright! I remember that even before I replaced them, one day my friend drove my car to pick me up at the train station after dark, I recognized my car from a very very very far distance among all other cars because of the bright lights!! And people have been flashing their lights at me all the time. Now I got pulled over?
    Any known solution to this? I think I did a search before and didn't seem to find a solution.
    Thanks.
  2. ursle
    ursle Gas miser
    1,049
    192
    NH
    If you have an 07 it has a mechanical head light leveler, I'm guessing yours is rusted and the lights are permanently aimed to high, or
    • Made in Korea
    • High Quality Maxlux HID Lamps
    • 3000 hrs. average lifespan
    • Ready to install right-out-of the box - 100% Plug and Play installation
    • Make sure the bulb is properly positioned. The bar is supposed to be pointed downward.
    You didn't install the bulbs properly, upside down to be exact, the wattage isn't listed, are they 100wats? =illegal;)
  3. weixulu
    NJ, USA
    I can switch between high and low beams.
    The light bulbs were bought from Amazon:
    (Why can't I insert an Amazon link here? )
    BrandPhilips
    Item Weight1.6 ounces
    Product Dimensions3.9 x 2.7 x 1.4 inches
    Item model numberD4R
    Manufacturer Part Number42406
    They were installed by Toyota dealership. I didn't install them.
  4. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    might be that your headlights need to be adjusted. any inspection shop should have a headlight aiming unit. takes about 5 minutes.
  5. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
    You could always put back the legal headlights. It is illegal to sell HIDs for public roads in the US on any car not factory installed with HIDs.
  6. wa-chiss
    wa-chiss Member
    124
    36
    Brownwood, Texas
    If it has the auto levelers, then it came with HIDs.
  7. PriusGuy32
    1,417
    510
    Harrison Township, Michigan
    When I bought my 2007, people would flash their high beams at me all of the time. So I used the mechanical adjustment and brought them down.
    Now, 2 years later it's happening again. I notice they are aimed high and people are starting to flicker their high beams at me again.
    I tested my leveling system and it works.
    To the OP: just aim them lower. I did and they are moooore than bright enough that you don't notice a difference but then it no longer appears that you have your high beams on.
