Pulling a 1,000lb Little Guy
Discussion in 'Gen 3 Prius Accessories and Modifications' started by bauerhillboy, Oct 5, 2013.
  1. bauerhillboy
    bauerhillboy Junior Member
    22
    Sorry...I'm not very good at doing searches...We decided to get a Little Guy 5 wide and we will use the Prius (2010). I am a very careful towing guy, and I know that any success I have in towing this camper will require very conservative operation. I have read about some sort of electronic monitor that I should get to keep tabs on temps. What is that item? And what else should I be thinking about? Thanks, John.
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved to the appropriate Gen III forum from the Prius c forums.
  3. bauerhillboy
    22
    OOPS...thank you.
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Scangauge 2. Autozone has one of the best internet prices around ($119.9X + free shipping), use coupon code DOW40. If you miss out on that one (expires 10/5/13), then try DOW41. ;)
    Here's a suggestion on what should be monitored (inverter coolant, MG1 & MG2 temps):
    Prius pulling a RV? What do you pull !! | Page 2 | PriusChat
    The whole thread is a discussion on towing with the Prius.
  5. bauerhillboy
    22
    Thank you : )
