Pulse and Glide Technique Details
Discussion in 'Gen 2 Prius Fuel Economy' started by ZooPrius, Jan 15, 2009.
  1. ZooPrius
    ZooPrius New Member
    Kalamazoo, MI
    I am only one month into Prius ownership and I am working on hypermiling. I realize it isn't really going to happen right now since it is -5 degrees outside, we have about 3 feet of snow on the ground and most of the roads have packed snow an inch or two deep. Still this week I am getting about 40 mpg more like 55 if you don't count the first 5 minutes of each drive. Most of my driving is 10-15 minutes on 35 mile an hour roads with some small rolling hills. I have a partial grill block using pipe insulation I learned about here. I have not gone for the EBH yet. There are too many environmental variables for me to do a trial and error method to learn how to do this for the next few months.
    I see people mention pulse and glide but I was hoping some of the hypermilers could give me some details:
    1. Are the pulses using the ICE or do you use the elective motor for this too?
    2. Do you use electric only for some of the pulses?
    3. How long are the pulses? Am I better off just trying to get back up to speed limit as quickly as possible so I can glide sooner or trying to keep the acceleration down to avoid burning up so much gas on the pulse?
    4. Is it better to pulse down a hill so I can roll up the other side or roll down the hill and pulse up the other side?
    5. Lets sayyou are driving in a 45 zone level ground how low do you let your speed get before you pulse back up. In other words are you doing long pulses (20 seconds) and long intervals (30-60 seconds) or short pulses (2-5 seconds) and short intervals (15 seconds)?
    6. On the glide part I notice the car glides better with my foot pushing down on the pedal just enough to eliminate all the arrows on the "energy screen". Is it better to glide this way without charging or will I just end up not having enough charge later on to drive in the electric mode.
    Thanks
    Prius Rising likes this.
  2. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    1. Pulses are with the ICE only. You should execute them to avoid either low-power with electric only or high power with electric boost to the ICE. Whether pulsing or gliding it is more efficient to avoid pushing power to or pulling power from the battery.
    2. No.
    3. Acceleration rates should be at a rate that avoids pushing the ICE into inefficiently high RPM ranges. Without a tachometer, if you keep the instantaneous MPG at least half the vehicle speed you'll generally avoid those ranges. Beyond that, since I generally drive in at least moderate traffic, I continually adjust pulse duration (and rate, to some degree) to stay safe and balance fuel economy and courtesy.
    4. Depends on the hill. On most hills I glide down and pulse up the other side. On a gentle downhill I might begin my pulse before hitting the nadir to help gain a little momentum for the climb.
    5. Again, much of that is guided by traffic. In a 45-MPH speed zone with moderate to heavy traffic, I generally don't P&G anyway. P&G is done at <40 MPH, and to be riding at, say, 30 MPH likely is unsafe. Even in light traffic, I might choose not to P&G. If following traffic can't pass (i.e., a two-lane road) or they might quickly approach me around a blind curve or hill, I'll stay close to posted speed limits. Instead, I seek alternative routes with lower speed limits or lighter traffic that offer more P&G opportunities.
    6. You've nailed it. That is the most common glide technique, and mastering it will go a long way to optimizing fuel economy.
    Finally, see this for perhaps the most complete discussion of P&G.
  3. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
  4. Bob64
    1,540
    93
    Virginia
    Thats a trick question. They're both combined such that its impossible to use the ICE without the electric motor. However, I believe you meant: Do you pulse with pure gas power (ICE) or with a mix of gas (ICE) and power coming from the battery (powering the electric motors)? The answer to that is: as much pure gas power as possible (ICE only) and as little use of the battery as possible.
    Avoid (at almost all costs) if possible.
    Depends on who is tailgating you (if any) and what the speed limit is. If theres no one tailgating me, I pulse to a speed that I feel will get me to point B fast enough while sticking as close to the "optimal speed" of 22mph. You may have to maintain speed at the speed limit if you have a tailgater. As for how "fast" you accelerate, try to stick between 1400rpm and 1800rpm.
    Depends on the hill and the speed limit. Its better to go down a hill as slow as possible WITHOUT hitting the brakes or regenerating (others may have differing opinions about this bit). If your hill causes you to accelerate above 41mph, shift into neutral before u hit 41, to prevent the ICE from spinning. Do not go above ~65mph in neutral with the ICE off (may overspin the motors... but the limit is debatable)
    As slow as I can go without pissing off the traffic behind me. Typically long pulses and long intervals between pulses, depending on traffic ahead of me. It is my opinion that the length of pulses doesn't matter as much as avoiding braking. Even if you do perfect pulses, all that effort will be wasted if you misjudge the slowdown ahead and waste 20mph of built-up speed.
    Charging isn't gliding. If your charging, your "coasting". If your hard-core, I'd recommend shifting into neutral once your sure the ICE is off, just to reduce idle electric draw from the inverter/motors. Be sure to shift back into drive BEFORE you hit the brakes (neutral disables regeneration)!! You don't want to drive in the electric mode.
  5. dominicsavio
    dominicsavio New Member
    83
    One more thing ZooPrius- patience and practice. It's also what I am learning. You're already at 40 mpg in very cold conditions so you've got to be doing many things right. Many people drive for a year or two before nailing this...
  6. dominicsavio
    83
    "If your hard-core, I'd recommend shifting into neutral once your sure the ICE is off, just to reduce idle electric draw from the inverter/motors. Be sure to shift back into drive BEFORE you hit the brakes (neutral disables regeneration)!! You don't want to drive in the electric mode. ?"
    Bob - whats the best approach when shifting to N while driving? and Why do you shift to N? I guess because shifting to N allows the car to go further quicker because of 'extra' momentum arising from the 'free flow' which would not otherwise occur when the car is engaged in CVT (regardless of whether you are gliding or not)?
    I'd really like to get a take on this from people who do this...
    Check out this post also for some discussion on this http://priuschat.com/forums/fuel-economy/56857-does-make-sense-shift-neutral-during-driving.html
  7. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Shifting to N gives the same effect has finding the accelerator sweet spot w/ no energy in or out. Downside is, there's no powertrain management for ICE control above 42mph (or so the debate goes on), so I'd only do it personally at lower speeds.
  8. JimboK
    2,817
    188
    49
    Chesterfield, VA
    Well, pretty close. There actually are very small differences in current flow and drag between the two techniques. See this for more. Fuel economy is very similar, so for the average P&G'er it probably doesn't matter.
  9. ZooPrius
    ZooPrius New Member
    Kalamazoo, MI
    Thanks for the advice. I drove to the auto show this weekend about 135 miles and got 53 mpg using most of these techniques. It was nice to see the little tank go that far. I also noticed how much drafting off a truck can help. I had previously thought it was insignificant but with the instant feedback I can see it is not especially on level ground or a slightly downward gradient.
    I did not know about the shifting into neutral thing since that discussion was posted after my trip. Since this was a lot more highway driving than city and more than I had done in one trip in over a month the techniques are definitely different. At highway speeds I had a very hard time getting the "sweet spot". I found it only for a few seconds. Is this what is supposed to happen? Is this why some of you are using neutral?
    Thanks
  10. ZooPrius
    ZooPrius New Member
    Kalamazoo, MI
    What does this mean? Don't we want the power train disconnected for rolling purposes or is that a problem at higher speeds?
  11. Bob64
    1,540
    93
    Virginia
    Shifting to neutral has the following effects:
    1) Preventing the ICE from turning on or off. Useful if going downhill and accelerating beyond 41mph, and you don't want to turn on the ICE.
    2) Reducing energy drain
    Neutral doesn't allow the car to go further, it goes a bit shorter due to the energy that isn't flowing to the motors.
  12. HTMLSpinnr
    5,341
    920
    251
    To be perfectly clear, the wheels are ALWAYS connected to MG2, MG2 to PSD, and PSD to ICE and MG1. Neutral is simply a "logical state" for power train management.
    Only way you'll physically disconnect is if you break the final drive chain... ;-)
  13. JimboK
    2,817
    188
    49
    Chesterfield, VA
    I don't use neutral at >41 MPH, except to the extent I might shift into N at lower speeds on a downhill where speed can subsequently drift higher. (NOTE: Driving in neutral on a downgrade is illegal in many states.) If you shift into N at higher speeds, the ICE will run while in N. Better at those speeds is to deploy what some call warp stealth, which allows ICE shutdown. It is very similar to gliding, but is done at higher speeds. It is described here and in the link in my first post in this thread.
  14. bwilson4web
    15,999
    You might also take a look at the warm-up stages. Getting your car into S4 lets the vehicle engine cycle off at many opportunities that otherwise might be lost. Maddening, it often requires coming to a complete stop so the engine can 'shut off' and then you are in full hybrid mode.
    My first 1-2 miles focuses on getting into S4 at the earliest opportunity. Thereafter, normal 1970s speed routes work pretty good.
    One other technique is parking. In the winter, I see a nice, bright sunny area close to the parking lot exit. This lets me use battery power during the earliest 45 seconds to improve initial MPG and the sun is a pretty good space heater. In the winter, I'm parking in the shadiest possible place for battery longevity and AC avoidance.
