Pulse and Glide
Discussion in 'Gen 2 Prius Main Forum' started by hjon71, Mar 30, 2006.
  1. Yes
    0 vote(s)
    0.0%
  2. No
    0 vote(s)
    0.0%
  3. I would but I'm too lazy.
    0 vote(s)
    0.0%
  4. Whats P&G?
    100.0%
  5. 0 vote(s)
    0.0%
  1. hjon71
    hjon71 Junior Member
    98
    I just found out about this, So I thought I'd do a test.
    I had an 80 mile trip to Memphis the other day. It was mostly 4-lane,65-70 mph, with a few small towns,35-40mph. Outside temp about 65 both trips.
    On the way there I ran the CC (set at 70)whenever possible,and in the small towns I just drove as I would any other car. Aver. MPG=45.3
    For the trip home I decided to try P&G. Accellerating up hills and lifting completely off the gas just before the crest and coasting or barely pressing the gas pedal to maintain speed. Speed varied some but tried to maintain 70 as best as I could. Aver. MPG 53.8
    One more consideration. I "figure" that driving west toward Memphis is slightly downhill. So perhaps My findings might be slightly skewed.
    Just wondering if others have tried it and how they did. I must now admit that my right leg did get tired but If I can manage this MPG it might be worth the PAIN.
  2. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    <div class='quotetop'>QUOTE(hjon71 @ Mar 30 2006, 07:54 PM) [snapback]232741[/snapback]</div>
    You need one more choice. I live and breathe Pulse and Glide. I got 65 m.p.g. how are you doing? OK see below only below 34 mph but still it does make a difference from "just drive it". OK you have to find a route to and from work where you will not pixx too many people off doing this, or someone will run you over. I modified my route, and gained about 10 m.p.g. but lost 4 Min on the trip. You decide. Also I am a bit more mellow at lower speeds and the pigs ( sorry child of the 60's) don't bust my chops. B)
  3. Betelgeuse
    Betelgeuse Active Member
    1,460
    23
    New York, NY, USA
    <div class='quotetop'>QUOTE(hjon71 @ Mar 30 2006, 10:54 PM) [snapback]232741[/snapback]</div>
    Nice results. I should just say that this is not what most people are refering to when they say "Pulse and Glide." The traditional P&G happens only at lower speeds (it's best between ~30 MPH and 40 MPH) and involves accelerating moderately up to the top speed (i.e. ~40 MPH) and then "gliding" down to 30 MPH. The "gliding" is accomplished by having your foot lightly on the accelerator so that you see NO ARROWS on the MFD. I think it's impossible to get into this "no arrow" mode at highway speeds.
    It's actually been discussed here before that the CC in the Prius is overly aggressive (i.e. it REALLY wants to keep you at the given speed), so it can acclerate hard at times (at the expense of fuel mileage). I'll just say that I've experienced my best mileage on hilly terrain by accelerating as little as possible on the hills (accelerating while going up hills takes a lot of gas) and using the downhill part to gain speed back.
  4. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    Darn, I thought this was another sex poll!
  5. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    868
    151
    Northern California
    2012 Chevy Volt
    I find it difficult to to for two reasons. 1) Too much traffic where/when I drive. P&G causes too much variation in speed. 2) The times I've been out w/o other cars around I get too impatient doing the P&G and after a few minutes go back to "regular" driving.
    Happy with my 45mpg driving like I always have.
    Jeff
  6. rdenneyutmb
    rdenneyutmb New Member
    31
    <div class='quotetop'>QUOTE(San_Carlos_Jeff @ Mar 31 2006, 11:03 AM) [snapback]232969[/snapback]</div>
    I have a new '06 with about 1400 miles on it. I have been pulse-and-gliding to work (30-40 mph), about 22 miles each way, by choosing to take a virtually abandoned feeder road from my home to Galveston, rather than driving at higher speed on the freeway parallel to it. (I cannot avoid a short stretch of about 3 miles of Freeway that includes up and over a substantial causeway, regardless. The freeway stretch is I drive at a steady 55 mph.) I have been averaging 70 mpg for the P&G commute. If I take the freeway all they way at a steady 55 or so, I get about 50 mpg. These figures are for mostly flat terrain and temperatures of 65-75 F. What I haven't done is compare the P&G results with the same route taken at a constant, slow speed (about 37 mph). I will try that some time.
    P&G has become a new hobby. But you have to have the right place to do it and some extra time...
  7. jeneric
    jeneric New Member
    442
    Redmond, WA
    <div class='quotetop'>QUOTE(Betelgeuse @ Mar 30 2006, 08:04 PM) [snapback]232748[/snapback]</div>
    Not impossible, just not really useful because the ICE will still be turning. So you don't make up the efficiency lost from the acceleration.
  8. hobbit
    hobbit Senior Member
    4,087
    454
    Bahstahn
    At highway speeds it won't be "no arrows" mode. But it will be
    "electric drive only", battery to motor to wheels with no ICE
    contribution. That's warp-stealth, and it's hard to hold because
    it's even more touchy than low-speed gliding, but it is a *serious*
    mileage win if you can do it, especially in that "mid-speed" range
    between 42 and say 55-60.
    The potential confusion comes because the ICE is still spinning, but
    is being spun *by* the combination of electric motors with no fuel
    consumed. Takes a couple of kilowatts to do it, but less overall
    than burning more gas.
    _H*
  9. ellisfam2
    ellisfam2 New Member
    I P&G to and from work every day. It's about 15 miles each way, all two lane back roads and constantly up hill/down hill. Even in the dead of winter (Maine) I can get between 47-49 mpg. This past tank of gas is being consumed with temps during the day of 48-70 and night temps in the high 30s. So far, Im at 58.4. It's amazing what outside temps do to your mileage, wheather you P&G or not.
Loading...
