pump MPG calculation vs. trip calculation
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by eric smith, Nov 19, 2012.
  1. eric smith
    eric smith Junior Member
    44
    DC/Maryland
    I just filled up for the first time while paying attention to the trip calculator vs math at the pump. I was getting 68 MPG's on the trip, but when I did the math problem at the pump it only equated to 65 MPG's. Is this the appropriate amount of error, or does this seem high?
    thanks
  2. raimix
    raimix Member
    204
    33
    Long Island NY
    last tank comp read 63 mpg, calculated was close to 59.
    use fuelly, it's great for calculating real mpg
  3. eric smith
    44
    DC/Maryland
    Thanks,
    I am currently using fuelly, but I do not have enough data to get an exact MPG reading yet.
  4. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    calculated vs. computer MPG - Please post your results | PriusChat
    My dash reading reads 4.5 to 7.5% higher than actual MPG calculated, with it mostly being in the 6 to 7% range.
  5. bisco
    52,677
    please enter your data in the pip spreadsheet sticky, thank you.
