Purge valve switch
Discussion in 'Gen 3 Prius Main Forum' started by Southern81, Jul 24, 2019.
  1. Southern81
    Southern81 Junior Member
    Lexington Ky
    Hello, can someone tell me if the purge valve and purge valve switch are two different things?
    I have an 07 with 210,000 miles. Codes are p0441 and p0455. I put new ome gas cap on with no luck. Took it to a local guy that works on Prius’s and he said I needed a purge valve switch.
    Where is this part located? Can it be changed easily? Thanks
