Pushing the v to the limit
Discussion in 'Prius v Fuel Economy' started by perry470, Dec 13, 2018.
  1. PriusV17
    PriusV17 Active Member
    402
    199
    CA
    2017 Prius v wagon
    Latest oil report at 35k. They recommend that I don't change the oil and go for 10k oil change. So I am doing that.
    This was on all K&N. Silicon levels remain at their lowest. But right after I submitted this sample SoCal had a major dust storm. Which may or may not affect the next sample report.
    An interesting thing to note is the increase in molybdenum levels. It's at it's highest level and apparently that is a good thing. Moly is added to fuel additives to prevent wear on engine metals. And I believe it is because of this that my iron levels are at the lowest level ever. All other readings are consistently low.
    More info on moly:
    Molybdenum-sulfur compounds in lubrication
    "A layer of molybdenum atoms is sandwiched between two layers of sulfur atoms. When molybdenum disulfide is dispersed between two metal surfaces a layer binds to each metal surface through the sulfur atoms. Then the asperities (surface irregularities on the metals) are prevented from coming into contact. Sliding contact is between the outer layers of sulfur atoms which are only weakly interacting. The surfaces are therefore able to slide easily relative to one another (Fig. 2)."
    Reason my moly levels are so high is probably because I add Sea Foam to every fill up. Not a full can but half on average. I like the smooth accelerations along with the K&N filter that gives it additional air flow.
    So far very pleased with the results.
    Also I've been doing some reading that recommends to once in a while drive the car at high speeds to clean out the system. From EGR to Catalytic converter. The cat converter needs to be flushed out and the high speed gives it the heat needed to burn out and clean out the system.
    2019 Tips on how to Fix a Catalytic Converter (Without Replacing It) – Automobile Problems | Cars | Engine Problems | Autocareplanet.com
    "The “Italian Tune-Up” is a very common fix for a range of automotive problems, including a clogged catalytic converter. You know many drivers simply don’t push their vehicles hard enough to heat the catalytic converter to its most-efficient temperature—between 800 °F (426 °C) and 1,832 °F (1,000 °C)—leading to premature failure.
    Running a vehicle harder than usual for a few miles (e.g. multiple hard accelerations) could also heat up the converter adequately and burn off performance-robbing deposits in the intake, cylinder head, exhaust, oxygen sensors, and catalytic converter.
    Fuels and Fuel Additives
    A different fuel or fuel “additive” may be effective at cleaning out catalytic converter deposits. For example, if what you do is fill your vehicle with the cheapest low-octane fuel, try running your vehicle on a few tanks of high-octane fuel."
    For me K&N and Sea Foam allows me to push my v to the limit and not worry too much. The data reassures not to worry. And pushing the car is needed once in a while to clean gunk out. Like we humans need to clean out our system by vigorous exercise once in a while
  2. PriusV17
    402
    199
    CA
    2017 Prius v wagon
    Ok this is probably the last report I'll post since data is still consistent. Overall nothing unusual after 40k miles on odometer and 10k miles on the oil. All previous reports were based on 5k oil changes. So this one was based on 10k. I haven't been driving it much since the covid lock-downs and no planned road trips.
    The only metal that showed noticeable increase was Iron. But the increase was consistent with the increased interval from 5k to 10k oil change as mentioned in the report.
    Iron wear sources from bobistheoilguy.com:
    "This is the only wear metal that accurately and linearly increases with the length of time the oil has been in service. It has many sources inside of an engine, most commonly coming from cylinder liners, camshaft lobes, crankshaft journals, and oil pumps."
    Silicon (sand particles) only increased from 6ppm to 9ppm (only 3ppm jump) which is very low for 5k additional miles on oil.
    Moly only increased from 135 to 137ppm which seems to disprove my theory that it came from the additive I was adding (seafoam). So I'm not sure where the moly is coming from.
    When I knocked the k&n filter to get some dirt out, I did notice lots of sand and even small rocks. The clean side is clean and the dirty side dirty. When I knocked off the dirt I make sure to knock in the direction of the dirty side. I have not cleaned my filter and may do that in another 10k. Or just buy a new filter and not bother with cleaning.
    So overall pleased to see low metal wear while still able to get power and performance I want.
    These oil reports I feel are very useful to gauge what is happening inside an engine. It doesn't give complete information but good information where red flags can be detected early and addressed early.
  3. PriusV17
    402
    199
    CA
    2017 Prius v wagon
    I tried 2 different oil pumps. The commonly sold WIX version (red/black) and the Blackstone pump.
    The WIX version became difficult to pump for some reason so I switched to Blackstone's pump. Blackstone's pump is very smooth and easier to use.
    WIX is more pricey ($40-$60) than the Blackstone pump ($35). Blackstone provides the tubes as well. Extra tubes can also be bought at homedepot.
  4. PriusV17
    402
    199
    CA
    2017 Prius v wagon
    Ok it's been 75k now and oil reports still looks good. I'll post again in 150k miles or if I encounter any issue (if I still have the car).
    For this report. It was 5k oil and had some good straight 3000ft climbs (probably 10 times). Still on K&N engine filters and still all on PWR mode. For the engine oil I did something new, I decided to add 3 oz of Liqui Moly MoS2 anti friction into the engine oil and 3 oz of Seafoam into the engine oil.
    The results are good. But I was surprised to see still the same level of Moly in the report. If there is Moly in the Liqui Moly treatment I assume it got "plated" into the engine parts. Since Liqui Moly is designed to coat the engine parts especially where there is friction.
    After all these years of running Seafoam in the gas treatment I highly recommend it. I can tell the difference in engine performance. I always add from a quarter to a half in every tank. But when I add a full can into the gas tank the engine is so smooth and quieter at full throttle.
    For the oil pump tubes you can also use windshield washer hose it will fit the pumps just fine.
    LIQUI MOLY MOS2 Anti-Friction Engine Treatment 300ml.png 71Tc6dvoSVL__41050__85123.jpg PRIUS-V-2017-75K.png
  5. Air_Boss
    Air_Boss Senior Member
    4,231
    1,190
    New Yawk
    2012 v Five here. Just noticed this thread.
    Are the various oil and fuel additive performance indications all ‘butt dyno’ measurements?
  6. PriusV17
    402
    199
    CA
    2017 Prius v wagon
    Ear dyno. I expected moly count to be much higher. So data is what it is.
    Air_Boss likes this.
  7. PriusV17
    402
    199
    CA
    2017 Prius v wagon
    Wasn't planning to post this, but the "write the book" part got me to do it.. :cool:
    "Whatever you are doing to take care of your Prius, please, keep it up! This report is looking as great as the previous ones. Everything is trending excellently. We aren't seeing any strange spikes in wear or any peaks and valleys, just some slight fluctuations that are typical in oil analysis. There aren't any signs of problems in these numbers. The physical properties of the oil are also in line with where they should be. We recommend doing exactly what you've been doing. In fact, you could write the book on how to take care of a car. Stellar report!"
    This oil has tons of uphill mountain climbs. At times I raced other cars going 80+mph going up a highway mountain incline. Just to push the power to the limit a bit. Was a bit concerned if my readings would start to show it's wear. But so glad to get the "write the book" out of it! Always still driving in PWR mode with same stuff as before. :)
    farmecologist likes this.
  8. PriusV17
    402
    199
    CA
    2017 Prius v wagon
    The numbers are starting to go into reverse :)
    Same setup (seafoam in gas, k&n engine air filter and about half a bottle of liquimoly MoS2 in engine oil per oil change).
    Still on PWR mode and going up lots of mountain inclines at high speed, that is now driving normal for me.
    "Thanks for noting the additives you used. Those don't skew our analysis, but it's nice to have all the info anyway. This is another good report for your Prius. Both aluminum and iron decreased by 1 ppm from their levels in the previous report, and that's always good news, regardless of how small the change was. There are no contamination or filtration issues to contend with either, so this is an all-around spotless report!"
  9. Air_Boss
    4,231
    1,190
    New Yawk
    Molybdenum is way up. Using more MoS2?
  10. PriusV17
    402
    199
    CA
    2017 Prius v wagon
    Before a quarter of a bottle of MoS2, now I put half a bottle because of all the mountain inclines I've been doing. Half seems to work just fine. Now I have to take at least half to a full bottle of Seafoam because of the mountain climbs. Seafoam is to lubricate fuel. Less than that or no Seafoam, I notice more engine struggles (noise). My current setup makes my engine smoother and quieter at high speeds climbing mountains. I think at high RPM the moly starts to plate the engine where ever there is friction. Just a theory. If the numbers keep reversing then I think likely the plating is going on.
  11. PriusV17
    402
    199
    CA
    2017 Prius v wagon
    If moly plating occurs then what you get is a much durable metal coating the engine with much higher melting point.
    Moly melting point: 4,753°F
    Iron melting point: 2,800°F
    Aluminum melting point: 1,221°F
  12. Air_Boss
    4,231
    1,190
    New Yawk
    ‘Lubricate the fuel’ in what location? Tank/sump pump, high pressure pump, injectors?
  13. Air_Boss
    4,231
    1,190
    New Yawk
    MoS2 frequently used in transaxle and gearbox lubrication.
  14. PriusV17
    402
    199
    CA
    2017 Prius v wagon
    Diesel engines can run up to a million miles. Gas engines maybe 200-300k miles. The main reason? Diesel has lubrication properties in the fuel. So adding Seafoam gives gas that important lubrication property.
    Google AI summary:
    "Diesel fuel has natural lubricating properties that help reduce friction and wear on internal engine components, unlike gasoline which is more of a solvent."
    "Seafoam lubrication works by using its petroleum-based, solvent-like formula to dissolve and liquefy harmful residues, sludge, and carbon deposits in the engine and fuel system. When added to crankcase oil, it breaks down sticky deposits that can restrict oil flow, allowing them to be drained out with the old oil. When added to fuel, it cleans fuel injectors, intake valves, and combustion chambers to keep the engine running smoother and cleaner.
    It works to clean and lubricate fuel injectors, intake valves, and combustion chambers. This helps remove carbon and varnish, leading to a smoother idle and better engine performance."
  15. PriusV17
    402
    199
    CA
    2017 Prius v wagon
    More AI summary about MoS2 for anti friction:
    "molybdenum disulfide (MoS2) is used to plate metal parts at friction zones by forming a low-friction, protective layer that reduces wear. Its layered structure allows the layers to slide easily over one another under pressure, preventing direct metal-to-metal contact and its associated friction and wear. How it works Layered structure: MoS2 has a layered atomic structure with molybdenum atoms sandwiched between layers of sulfur atoms.Low friction: The weak forces between the sulfur layers allow them to slide past each other with ease, creating a low-friction interface when MoS2 is applied to a surface.Binding to surfaces:
    During application, the sulfur atoms can bind to the metal surface, creating a durable film of MoS2 that acts as a protective coating. Benefits Reduced wear: By preventing direct metal-to-metal contact, MoS2 significantly reduces wear and extends the life of the components.Low friction coefficient: It can provide a very low coefficient of friction, sometimes as low as \(0.05\).Corrosion inhibition: It can help protect parts from corrosion, especially when combined with proper resins and binders.High-temperature performance: MoS2 is effective at high temperatures, maintaining its lubricity in high-load, high-speed conditions. Applications Automotive: Suspension systems and other moving parts.Industrial machinery: Bearings, gears, and other components that experience friction.Aerospace: Components in aircraft and spacecraft.
  16. PriusV17
    402
    199
    CA
    2017 Prius v wagon
    This guy posted before and after Seafoam in the crankcase. I typically add a few oz 500-1000 miles before an oil change.
    Before:
    After:
  17. PriusV17
    402
    199
    CA
    2017 Prius v wagon
    Now at 95k miles. Reports are still "spotless" and the wear numbers are still going into reverse.
    "It's another spotless report for the collection! The Liqui Moly MoS2 you added is evident in the high molybdenum level. The Sea Foam didn't skew anything in analysis. Wear is still low with only aluminum and iron showing up at 3 ppm and 2 ppm, respectively. We have no reason to suspect a developing mechanical issue with wear trends like this. Fuel, moisture, coolant, and excess dirt stayed away. Good results!"
    They still don't know that I'm still driving up mountain highways at very high speed.
  18. darknd666
    darknd666 Junior Member
    164
    Jacksonville, NC
    I feel its a misconception. K&N filters need maintenance to perform the way they were designed, filter needs to stay oiled and clean for it to work properly. I have seen some K&N disposable performance filters for my 2007 Yaris, havent tried them yet TBH. If only there was more room to put a larger filter that was just as restricted as the stock to compensate for volume loss, same reason why cone filters are used. More surface area.
  19. PriusV17
    402
    199
    CA
    2017 Prius v wagon
    I don't bother to re-oil. I replace the filters every 30k miles. Toyota engine filters cost me $30 and I find myself replacing them at 10k intervals based on dealer inspections. So spending $65 on K&N (and then getting $10 cash back from OReilly) every 30k vs $90 for Toyota for same miles still saves me money. I thought about re-oiling, but i don't want to deal with the mess. I do save all my filters just in case I want to re-oil in the future.
  20. darknd666
    164
    Jacksonville, NC
    Anytime I have used a K&N i havent had it in service long enough to get to a washing...and the one rare occasion where I did, I just replaced it rather than cleaning because I dod not want to go through the cleaning process. Same with my HVAC filters, I use the disposables in between cleaning the reusable ones.
