Putting the car in Park while moving
Discussion in 'Gen 4 Prius Main Forum' started by Gen 2 Tom, Jun 8, 2017.
  1. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    Well I did it at about 40MPH. I was looking around for the mode button, when I mistakenly pushed the park button. It went to neutral and some message on the display. I was in a small panic trying to get it back into drive. No damage done. I have pushed it at a very low speed roll and it will go to park. So what is speed it does it do one or the other, I don't know.
    52,863
    up to gen 4, around 6 or 7 miles an hour, but i'd advise against it. they put some buttons in terrible locations.
    RCO and 'LectroFuel like this.
  3. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    I did it backing up attempting to close my garage door. It just gave a warning, if you want to perform emergency stop, hold button or something to that extent. I know it didn't stop the car, perhaps it went into neutral.
  4. fuzzy1
    10,714
    Previous Prius generations were well protected against damaging user error in mis-selecting Park and Reverse. I'd be quite surprised if Gen4 went backwards on this.
    Highway speed Reverse and Park attempts produce the same warning and result -- instant Neutral with a double beep warning.
    I've occasionally practiced shifting to Reverse at highway speed ever since the Sudden Unintended Acceleration scare of 2010, as a faster way to get into Neutral than the delayed shift lever. A reflexive Neutral was one of two things that saved me from damage in a previous car, when extreme fatigue led me to commit a driver-induced SUA while parking. The Prius is our only household vehicle without a manual clutch, so something else is required to disengage the propulsion system.
    RCO likes this.
  5. Mendel Leisk
    42,358
    A traditional automatic shifter is less error prone, both for accidentally choosing Park, or forgetting you're in Reverse?
    RCO likes this.
  6. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    Perhaps, but then it would possibly preclude auto-park at power-off, which you might consider an important safety feature.
    RCO likes this.
